Bullseye Batmowheel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 05-29-2011, 04:25 AM Thread Starter
NoSlow6.0's Avatar
Bullseye Batmowheel
Anyone running one of these on the 6.0 yet if so what are your thoughts?
10's ???
NoSlow6.0 is offline
post #2 of 31 (permalink) Old 05-29-2011, 06:14 AM
darklcdfeller's Avatar
Re: Bullseye Batmowheel
Interested aswell. Subscribed.
06 EXLB leveled with 35's with 20" Fuel Hostages, Autometer gauges (trans, boost, pyro, fuel pressure) 4" turbo back into 6" Black Chrome Stacks, intake...
Soon to Come: full build
darklcdfeller is offline
post #3 of 31 (permalink) Old 05-29-2011, 01:07 PM
strokin6L's Avatar
i believe craig and mike have one on their race truck over at Maryland Performance Diesel.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #4 of 31 (permalink) Old 05-29-2011, 01:51 PM
07_powerstroke's Avatar
07 ford f250
Josh Vandyke
07_powerstroke is offline
post #5 of 31 (permalink) Old 05-29-2011, 02:42 PM
Car Ramrod
06f250powerstroke's Avatar
i wonder how it would work on say a set up like 190cc- 66mm s300 with a diverter?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
pure performance 4 link
BD diesel Diverter Valve
06f250powerstroke is offline
post #6 of 31 (permalink) Old 05-29-2011, 03:01 PM
<-- Got Air ?
Craig@MPD's Avatar
Working very good for use did 11.16 on standard billet and 10.88 with batmowheel spool up is great and boost picked up about 10psi
I think one of these wheels would work very well in the 6.0 because you can basically have a 64mm wheel that flows as much as a 66 and so on
post #7 of 31 (permalink) Old 05-29-2011, 05:36 PM
strokin6L's Avatar
craig...how much of a PITA is it to swap out and change compressor wheels? Would anything else besides the compressor have to come off to do the swap? Also, i think you put the wheel on without balanceing...correct? Do you sell them, and how much? I might be interested in one then when i swap out my .70 non gated turbine housing for a gated one. I might as well do the batmowheel at the same time.
post #8 of 31 (permalink) Old 05-29-2011, 05:54 PM
Car Ramrod
when you say a 64 batmowheel would flow as much as a 66 will, will it spool quicker then a normal 64 and flow as much air as a 66 would?
64mm non vvt
190cc
FASS 95GPH
CFM
ARP's
IDP FICM
MBRP-4"
KMC Rockstars
BFG-KM2
post #9 of 31 (permalink) Old 05-29-2011, 06:06 PM
I believe that is what he means by that. From everything I have seen on it and read about it, that is a correct statement.
post #10 of 31 (permalink) Old 05-30-2011, 01:07 AM
Matt05's Avatar
Bullseye will not sell just the wheel. You have to buy a whole charger from them.
Matt05 is offline
