Fuel pressure guage questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-26-2011, 09:51 PM Thread Starter
06-6.0 stoker's Avatar
Wanting to install a fuel pressure guage on my 2006 6.0
Anyone using a good guage or guage kit?
Where do you usaually tap into the system for a pressure reading?
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #2 of 10 (permalink) Old 05-26-2011, 10:24 PM
Along for the ride
majek5's Avatar
Re: Fuel pressure guage questions
Front of the fuel filter housing at the bottom is a test port. It is an allen head plug.
06 F350 6.0 KR CCLB FX4...stock
majek5 is offline
post #3 of 10 (permalink) Old 05-26-2011, 10:51 PM Thread Starter
I know the plug you are talking about. Any idea what kind of threads it has?
What gauge to use and adaptor?
post #4 of 10 (permalink) Old 05-26-2011, 10:51 PM
06powerstroke's Avatar
I use a billet cap for mine... I have an autometer 0-100psi gauge
This will give you all the info on the test port...
Install Pictures
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #5 of 10 (permalink) Old 05-27-2011, 12:06 AM
Along for the ride
majek5's Avatar
FirstCoastDieselPerformance.com -- Your Source For Powerstroke Performance
majek5 is offline
post #6 of 10 (permalink) Old 05-27-2011, 12:24 AM
Administrator
Zmann's Avatar
male M12x1.5 o-ring to 1/8 Female NPT
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 10 (permalink) Old 05-27-2011, 03:53 AM
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
This is there new web site same place just a different name
6.0L Fuel Pressure Adapter
I'm running Autometer 0-100 i just ordered the gauge less the adapter fitting because the fitting comes with the hose.
If you get a fuel pressure gauge and your pressure is low this is the fix.
Mine before i installed the fuel pressure gauge i had 50 lbs at idle and 44 at WOT and that is to low, installed the kit now 62 idle and 58 WOT, low fuel pressure will kill injectors and over 70 lbs may blow injector o-rings.
The Reg. Kit number is 3C3Z-9T517-AG and you get it form Ford
The spring is located behind the small plate that the return line attaches to. This is probably one of the easiest repairs you can make... Take the four screws loose (they are T-27 torx screws), change pull the old spring out of the brass cup, put the new spring in and re-install the plate. When you are taking it loose, keep your thumb on the plate so the spring/cup doesn't pop out and also use your thumb to hold the plate up tight to the fuel bowl when re-installing, so the screws can be threaded in good. If you buy the whole kit (which I think is the only way you can get it from Ford), I would replace the brass cup while you are at it..
You can see the plate and return line here.
Page 30: Fuel Supply System
The only hard part is the hose is in the way, you need to get a turkey baster a new one and suck out all the fuel from the upper filter houseing that way you don't have a mess. After you are done you have to cycle the key 3 time 30 sec. each time to prime the fuel system.
Here you go this is a post by Band Member on the fuel pressure reg spring install over at the Dieselstop
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #8 of 10 (permalink) Old 05-27-2011, 12:01 PM Thread Starter
Thnx for all the info. Gonna get a few things ordered and try it out
post #9 of 10 (permalink) Old 07-13-2011, 02:29 PM
patmac6.0's Avatar
Install Pictures
03 eclb Whistler
6inch procomp, 37x13.5 m/t atzs, 18x12 pacer, 5in straight pipe, sct x3, and glowshift guages
patmac6.0 is offline
post #10 of 10 (permalink) Old 07-13-2011, 06:11 PM
6.0..........
STRAIGHTSTROKEN04's Avatar
Well since your around the fuel bowl, probably wouldnt hurt to go ahead and add the blue spring to help keep fuel pressure up.
04 H-D Edition, Intake/exhaust/SCT
STRAIGHTSTROKEN04 is offline
