Water Meth ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-25-2011, 05:48 PM Thread Starter
farming_stroker7710's Avatar
Water Meth ???
im working on building a water meth system for my truck and i like everything hidden so i was thinking bottom of one of the intercooler pipes.
my question is which one, would the hot side or the cold side pipe be better?
any help or opinions are appreciated
2006 F350
EGR DELETE, 4IN TURBO BACK, ARP's,
FASS 160, DOZER'S RR, BULLSEYE S366 BATMO,
BULLETPROOF 58V, LIVEWIRE WITH GEARHEAD TUNES.
farming_stroker7710 is offline
post #2 of 7 (permalink) Old 05-26-2011, 12:33 AM
strokin6L's Avatar
Re: Water Meth ???
cold side would be better. There's no sense having it going through the intercooler. I have two nozzles right into the CFM+ intake elbow.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 7 (permalink) Old 05-26-2011, 01:21 AM
Re: Water Meth ???
Sure to you have water building up in your intercooler sounds like an extra 100hp right their
2005 6.0 CC SB 4x4
Special thanks to Doug at GoGoDiesel
4x4freak is offline
post #4 of 7 (permalink) Old 05-26-2011, 01:24 AM
In The Passing Lane
SSpeeDEMONSS's Avatar
Re: Water Meth ???
i have heard of guys running a nozzle on the hot side and it helping to cool the intercooler and in turn cooling the air even more. though those guys also ran nozzle/s on the cold side too.
the one nozzle i had plumbed on my dodge was on the hot side but i never got a chance to run it before getting rid if it.
Garrett
2003 F-250 6.0 XLT CCSB 4WD 5R110- rebuilding it
1994 2500 12v RCLB 4WD 5spd- 382hp/1000tq gone but not forgotten
2000 GMC 2500 6.0 LQ4 4l80e RCLB 2wd
- stock
SSpeeDEMONSS is offline
post #5 of 7 (permalink) Old 05-26-2011, 02:36 AM
Extended Power's Avatar
Re: Water Meth ???
If you never ran the truck long enough afterwards...there would be a pool of water sitting at the bottom of your intercooler...(You would be creating a "trap", if you put it at the bottom of the piping.)
2003 F-350 KingRanch 4x4
Extended Power is offline
post #6 of 7 (permalink) Old 05-27-2011, 05:28 PM Thread Starter
Re: Water Meth ???
unless you set the controller to come on at 10#s of boost, then even if you let off the residual boost should push the rest up the pipe right?
2006 F350
post #7 of 7 (permalink) Old 05-27-2011, 11:44 PM
strokin6L's Avatar
Re: Water Meth ???
But you wouldn't want it to come on at 10lbs of boost...that's too early. Should have it coming on no less than probably 15-16psi.
