new swamps ficm and truck still wont stay running - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 05-25-2011, 12:52 AM Thread Starter
doofpowerstroke's Avatar
i just got a new 58v ficm from swamps put in last night and i was driving down the road after truck was warmed up and went wot and then easily let out and the motor died and it was pure white smoke. i need some help with this one i am stumped i have stage one injectors and and stock turbo. I had not put the programmer on it was just going to c how it ran and had to pull it back to the shop. i need some big help with this one.
2006 EXT CAB LB F350
S 300 62/80 non vgtFOR SALE
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
5 Inch Straight Pipe 8" Tip
325/65/18 Firestone MTs
XDP Sump
Coolant Filter
4 Piller Glowshift Gagues
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
doofpowerstroke is offline
post #2 of 31 (permalink) Old 05-25-2011, 01:14 AM
Administrator
Zmann's Avatar
Re: new swamps ficm and truck still wont stay running
got to ask?? why did u send the FICM to Samps ? did you have a failed FICM? or any other issue ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 31 (permalink) Old 05-25-2011, 01:17 AM Thread Starter
ya my stock one was shot
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #4 of 31 (permalink) Old 05-25-2011, 01:32 AM
motoxracer42's Avatar
whats it sound like when u crank it over?
06 crew cab
06 reg cab
motoxracer42 is offline
post #5 of 31 (permalink) Old 05-25-2011, 01:37 AM
Administrator
Zmann's Avatar
Codes??
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 31 (permalink) Old 05-25-2011, 02:04 AM Thread Starter
no codes and do u mean when i first started it
first start wired right up
then it wouldnt start agian i have some other problem killing my batterys
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #7 of 31 (permalink) Old 05-25-2011, 02:05 AM Thread Starter
started right up this morning and ran for 10 seconds pure white smoke
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #8 of 31 (permalink) Old 05-25-2011, 02:21 AM
does it sound funny at all while running? is the smoke constant or broken up?
06 crew cab
06 reg cab
post #9 of 31 (permalink) Old 05-25-2011, 02:30 AM Thread Starter
constant and it runs ruff like 3 or 4 seconds before it dies
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #10 of 31 (permalink) Old 05-25-2011, 02:54 AM
can you get ahold of another ficm? these trucks do goofy stuff when the ficm acts up. mine threw a cam position sensor code randomly and then wouldnt start. swapped the ficm and and it started right up. have you looked at your ficm voltage as its running? they will smoke if the voltage is bad. i know its a new ficm but bad batteries can hurt a ficm quick. check connectors and make sure you plugged them in all the way. normally it would throw tons of codes if you forgot that but its a start.
06 crew cab
06 reg cab
