performace between injectors and egt - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-20-2011, 10:57 AM Thread Starter
blead Ford Blue
gjoski515's Avatar
Send a message via Yahoo to gjoski515
Looking at Injectors, ok there are a ton out there, I would like 190cc, but the egts get high with them, are 175cc or 185cc any better? Should I just look at 175cc and that's it, if I were to go with 190cc twins would be better wouldn't it to keep the egts down
gjoski515 is offline
post #2 of 10 (permalink) Old 05-20-2011, 03:56 PM
Power Junky
Lubbockguy1979's Avatar
Re: performace between injectors and egt
The right turbo coupled with 190's would be a great setup. What do you plan to do with the truck? This will help out on suggestions
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #3 of 10 (permalink) Old 05-20-2011, 05:06 PM Thread Starter
blead Ford Blue
gjoski515's Avatar
Don't tow much, looking for some HP and being dependable
post #4 of 10 (permalink) Old 05-20-2011, 05:09 PM
strokin6L's Avatar
egt's can be very managable with 190's. It's in the tuning...they can be turned down so that they don't smoke and make high egt's. I ran 190's for a year with the stock turbo and never had a problem with egt's. Then when you decide to get twins or a bigger turbo, you can have them turned up to fuel more.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #5 of 10 (permalink) Old 05-21-2011, 01:58 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Ya I ran 190s with a stock 03 turbo for a while as well. Its all managable Greg.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #6 of 10 (permalink) Old 05-21-2011, 02:30 PM Thread Starter
blead Ford Blue
gjoski515's Avatar
cool think im going to go with the 190's, i like what i seen from your truck Kevin
post #7 of 10 (permalink) Old 05-21-2011, 03:16 PM
I would not go bigger than 175 and to keep egt's low.
smokersteve is offline
post #8 of 10 (permalink) Old 05-21-2011, 04:57 PM
6diesel6fuel6only's Avatar
do 190s mean allot more smoke if tuned right
6diesel6fuel6only is offline
post #9 of 10 (permalink) Old 05-22-2011, 01:53 AM
strokin6L's Avatar
190's can be turned down just like any injector can. 190's running at full potential will smoke alot with the stock charger. However if they are turned down some egt's can be very managable and there will be less smoke. It's been said alot....it's all in the tuning. Just tell whoever writes your tunes, that you have a 190's and want them turned down so that they don't smoke alot or have high egt's.
post #10 of 10 (permalink) Old 05-22-2011, 12:56 PM Thread Starter
blead Ford Blue
gjoski515's Avatar
thank you, when i get there new injectors i will have a different turbo also, thinking powermax here
