fuel bowl delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-19-2011, 02:11 AM Thread Starter
fuel bowl delete
howdo you do a fuel bowl delete i have a regulated returnsystem that i bought the feeds fuel from the back of the heads with a reg. at the front for the return whats the best way to plumb it all in and remove whats not needed on the fuel filter housing also i have a airdog 165 that has a built in reg that goes to 75 psi
pt444epsd is offline
post #2 of 11 (permalink) Old 05-19-2011, 02:17 AM
strokin6L's Avatar
Re: fuel bowl delete
i took a sawzall and cut the darn thing right off of the oil filter housing. All you gotta do is...instead of having the fuel line from the tank go into the factory fuel filter housing, just install a T and have it go straight to the front of the heads. Then the return from the aeromotive regulator can be hooked to the factory return line that goes back to the tank. I built my own fuel lines and system
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 11 (permalink) Old 05-19-2011, 02:21 AM
strokin6L's Avatar
Here's some pics.....
post #4 of 11 (permalink) Old 05-19-2011, 02:57 AM Thread Starter
i forgot to put i have a 7.3 not a 6.0.....my bad
post #5 of 11 (permalink) Old 05-19-2011, 03:02 AM Thread Starter
once again not paying attention and put it in the 6.0 not the 7.3
post #6 of 11 (permalink) Old 05-19-2011, 12:19 PM
Caterpillar Tech.
06deezel's Avatar
do you have any more pics of the return line and regulator setup? I want to build my own setup like yours
2006 F350 SRW 4X4
SCT Livewire with gearhead tunes
Egr delete
Sinister diesel coolant filter
8k HIDs
4" mbrp
35x12.50x17 nitto trail mt
06deezel is offline
post #7 of 11 (permalink) Old 05-19-2011, 01:18 PM
strokin6L's Avatar
I didn't make my own regulated return system tho....i bought that. I built my system from the tank to the heads using two different pumps and building my own fuel lines out of braided stainless and anodized fittings. When you buy a regulated return system, it already has everything in the kit to hook up the factory return.
here's a couple pics of the aeromotive regulator for the regulated return system.
post #8 of 11 (permalink) Old 05-19-2011, 01:21 PM
strokin6L's Avatar
You can see the return line in this pic. It's right next to the braided stainless line next to the MAF sensor. If you need a better pic of it let me know. I'll get one for ya.
post #9 of 11 (permalink) Old 05-20-2011, 12:25 PM
Caterpillar Tech.
06deezel's Avatar
Thanks for the pics they help....whos kit are you running for the regulated return system?...thinking about dfusers kit
2006 F350 SRW 4X4
Egr delete
8k HIDs
4" mbrp
06deezel is offline
post #10 of 11 (permalink) Old 05-20-2011, 01:08 PM
strokin6L's Avatar
LIDP(long island diesel performance)...they are no long in business. But dfusers and Strictly Diesel have good kits.
