Best Intake Manifold for the 6.0l?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-18-2011, 03:42 AM Thread Starter
gotsta go
anyone have an opinion for the best intake manifold for a 6 liter? cfm? s&b?
bigpower11 is offline
post #2 of 12 (permalink) Old 05-18-2011, 03:48 AM
Re: Best Intake Manifold for the 6.0l??
are u looking for an intake elbow or the actual manifold? intake elbows on 6.0s offer really no performance gain. they are pretty much for looks and an easy spot for injectables. cfm and s&b dont make intake manifolds so i assume u were talking about an elbow.
cfdeng7 is offline
post #3 of 12 (permalink) Old 05-18-2011, 01:06 PM
strokin6L's Avatar
If you are looking for an intake manifold...look into gogo diesel's manifold. If you want a intake elbow...i love the CFM+ large mouth. LIke said, very little performance gains will be had with a intake elbow. I have one cause it was easy putting water injection nozzles and a boost line to it.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #4 of 12 (permalink) Old 05-18-2011, 06:04 PM
<--won't start
Constantfix's Avatar
has anyone blown apart the stock plastic intake elbow, like found on 05's?
I did an intercooler and cfm at the same time, was just trying to remove as much plastic as possible.....maybe a double whammy of wasting my money, but i will say i dont pin my 1600 deg. pyro meter as fast anymore, if at all.
OP: there probably are better avenues to spend some money on your rig then the cfm+, in my humble opinion...do you have gauges?
Constantfix is offline
post #5 of 12 (permalink) Old 05-18-2011, 06:38 PM
FordSuperDuty05's Avatar
05s have a plastic IC tube not a plastic Elbow the 05s-07s have a metal eblow on them that hooks to a plastic IC tube
2011 F-350 Crew Cab Long Bed FX4 King Ranch
FordSuperDuty05 is offline
post #6 of 12 (permalink) Old 05-18-2011, 06:50 PM
Banned
Anyone know where to find the metal ic tube for 05-07's?
donzimama is offline
post #7 of 12 (permalink) Old 05-18-2011, 06:52 PM
Redneck6.0L's Avatar
You can order it from ford or I know bd diesel has them too
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #8 of 12 (permalink) Old 05-18-2011, 07:59 PM
<--won't start
yup, i got my verbage wrong...i meant to say the plastic ic tube off the metal intake elbow...thx for clarifying for my stupid fingers
post #9 of 12 (permalink) Old 05-19-2011, 12:22 AM
Banks has the best. They use a bigger boost tube. The bigger tube allows them to use a bigger elbow. Others use the stock size tube so theirs is smaller.
smokersteve is offline
post #10 of 12 (permalink) Old 05-19-2011, 12:29 AM
strokin6L's Avatar
Banks isn't the only one....CFM+ has a kit also that has the larger IC pipe to go with the large intake elbow. I have the CFM+ kit and have used the banks kit also(still have it) and personally i think the CFM+ one is better cause it is already drilled and taped for boost fittings and for nitrous and/or water injection nozzles.
Diesel Part # 20-113-022 - 03-07 Ford 6.0L PSD CFM+ Carbon Fiber Blue Hose Largemouth kit - Diesel Performance Parts
