Water kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-15-2011, 02:41 PM Thread Starter
6.0 money pit
smokinstroker's Avatar
Water kit
Who here has/is running a water kit on their truck? Looking for real data to tell me how much it helped with egt's.
smokinstroker is offline
post #2 of 14 (permalink) Old 05-15-2011, 02:54 PM
bring the chain
kyle43335's Avatar
Re: Water kit
Other than what the pyrometer reads what other data are you looking for? When you turn the water on and the puro stops increasimg and starts coming down. Thats enough info for me. I love it.
kyle43335 is offline
post #3 of 14 (permalink) Old 05-15-2011, 02:57 PM Thread Starter
6.0 money pit
Re: Water kit
How much of a decrease has it given you? Is this at wot or cruising?
post #4 of 14 (permalink) Old 05-15-2011, 03:34 PM
bring the chain
kyle43335's Avatar
Re: Water kit
That really depends on how much fuel you have. My Truck is different than yours. But to answer your question. The reduction in heat across the board is significant from to hot to good.
post #5 of 14 (permalink) Old 05-15-2011, 03:39 PM
Extended Power's Avatar
Re: Water kit
I saw about 200*F decrease when pulling my holiday trailer.
The adjustability on the Stage 3 is awesome. You can set it for boost pressure or EGT's.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #6 of 14 (permalink) Old 05-15-2011, 03:52 PM
strokin6L's Avatar
Re: Water kit
Love my stage II snow performance kit. Have 2 nozzles(625ml and 175ml). I only use it when i see a steep grade coming up or if i get on it hard. The stage III kit is the ultimate water kit from snow with more adjustability than the stage II. Like extentedpower said...i've seen 200* temp drop in my egts using mine. When it comes on at full tilt, i can really feel the power difference and hear it in the exhaust tone.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #7 of 14 (permalink) Old 05-15-2011, 04:08 PM
new2deisel's Avatar
Re: Water kit
It can be switched on the fly? I would like to be able to turn it on while towing a grade.
Everyone using just water or is it safe to use methenol too on a 6.0?
new2deisel is offline
post #8 of 14 (permalink) Old 05-15-2011, 04:23 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Water kit
Check out the Cooling Mist kits... Much better kits, pump's, Controlers and such.
Been running there stuff for about 7 years now.
Joe
CSIPSD is offline
post #9 of 14 (permalink) Old 05-15-2011, 04:25 PM
strokin6L's Avatar
Re: Water kit
Yes it can be turned on whenever. It's boost activated. Or if you have the stage III kit...it can either be boost or egt activated.
post #10 of 14 (permalink) Old 05-15-2011, 11:18 PM
Re: Water kit
I have run straight de-ionized water, -35*C windshield washer fluid, and have mixed my own batch of 50/50 that never got used yet. (Left it in all winter, so nothing would freeze up.)
