Towing Gears - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 05-14-2011, 07:57 AM Thread Starter
PSN Been daer dun it!
Cajunhunter67's Avatar
Towing Gears
Question? My truck is equiped with 4.10 gears. I would like to swap them to a 3.73. It pulls very easy no matter what the load. But the highway milage unloaded is crap. My 04 F250 had 3.73's in it. Milage was much better, but never towed with it? Will these gears effect my ability to tow...say up to 15k lbs?
FORD! Because its the only Option!!!
2008 F250. SCT Livewire Erics tunes. 4 in diamond Eye exhaust. AFE intake. EGR delete, 2.5inch Ready lift SST, 20inch Fuel Throttle wheels, 35in Toyo Mt. Amp Research Steps
Cajunhunter67 is offline
post #2 of 17 (permalink) Old 05-14-2011, 10:10 AM
Work&Play's Avatar
Re: Towing Gears
I have 4.10's and it pulls GREAT.
But my truck is also 12k everyday and I also tow a 10k dump trailer.
It is going to be big $ to change both the front and rear gears.
The saving in mpg most likely will not pay for the swap.
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
post #3 of 17 (permalink) Old 05-14-2011, 10:28 AM Thread Starter
Re: Towing Gears
Work&Play...apppreciate the input. How do you like the powermax turbo? Any diffrence in power? spool up on takeoff?
post #4 of 17 (permalink) Old 05-14-2011, 10:44 AM
Work&Play's Avatar
Re: Towing Gears
I like it a LOT
It helped with power and also lowered my EGTS.
I put it in last fall and is was good but I just got Matt to send me some new tunes for it and it woke it up quite a bit.
Plus it sounds SWEET, it tunes heads all the time.
post #5 of 17 (permalink) Old 05-14-2011, 10:45 AM
Work&Play's Avatar
Re: Towing Gears
On a side note how are doing with all the flooding down your way?
post #6 of 17 (permalink) Old 05-14-2011, 03:21 PM Thread Starter
Re: Towing Gears
Thanks for the info. I have been interested for awhile on the powermax. No flooding here. I am in the hilly part of Louisiana. But I do have family that lives right besides the levee, around New Orleans. Havent heard what they plan yet. Its not gonna be pretty for the southern part of the state.
post #7 of 17 (permalink) Old 05-14-2011, 06:09 PM
Power Junky
Lubbockguy1979's Avatar
Re: Towing Gears
The difference between 3.73 and 4.10 is not that great. How big of a difference are we talking mpg? How fast do you drive?
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
Lubbockguy1979 is offline
post #8 of 17 (permalink) Old 05-14-2011, 07:11 PM
Re: Towing Gears
I had an 02 7.3 with the 3.73 gears that got the same mileage and seemed to have about hte same power as my 04 with the 4.10 gears. The 7.3 with a tuner had about the same power as my 04 6.0 untuned. Personally I like the 4.10 gears it comes off the line much better and being in Colorado I do most of pulling above 7K ft the 4.10's for me are much better.
F350R is offline
post #9 of 17 (permalink) Old 05-15-2011, 03:28 AM
Twan's Avatar
Re: Towing Gears
We had a 2007 with 4.10, we put the 3.73 in it, I like the 3.73 better, but I run 75-80, never ran it with out trailer but Im sure it would help the mileage, it would take a long time to pay back, If you pull less than 15k it's worth the change, over 15 keep the 4.10.
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
post #10 of 17 (permalink) Old 05-15-2011, 04:14 AM
Re: Towing Gears
If you buy brand new gears it will be big bux. Look for used. used axle, totaled truck.....
smokersteve is offline
