Rocker arm in the way - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-08-2011, 02:27 AM Thread Starter
Maroon truck guy
Cutting-Edge Diesel's Avatar
I was pulling my 225s and on the #1 cylinder the rocker arm is preventing the injector from coming out. I had already busted my finger pretty bad and it was late so I didnt mess with it much. I did mess with it enough to figure it was the rocker and it was in the way and I couldnt get it out of the way. Have any of you had this problem? I was thinking maybe bent push rod or rocker but Im not sure. I was going to see if I could tell if the push rod was bent tomorrow. What do yall think?
06 F-250 project "Overbudget" in progress. Big Thanks to Innovative Diesel, GOGO Diesel and Gearhead Automotive Performance.
05 F-250 SCT ARPs, Track Bars FASS (For sale)
Cutting-Edge Diesel is offline
post #2 of 6 (permalink) Old 05-08-2011, 02:35 AM
<sideways skyscraper
Silverback's Avatar
Re: Rocker arm in the way
Make sure everything is out of the way then bump the motor over a few times it should clear.
06 CCLB 8" lift 37s 22s 8300#
[email protected]
Silverback is offline
post #3 of 6 (permalink) Old 05-08-2011, 02:39 AM Thread Starter
Maroon truck guy
alright ill try that thanks. ive pulled multiple injectors and never had this problem guess if it can slow me down its going to happen on this project.
post #4 of 6 (permalink) Old 05-08-2011, 02:40 AM
Attention Whore
UNBROKEN's Avatar
do NOT bump the motor over if you already have any injectors out....you'll fill those cylinders with fuel when the pump kicks on.
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #5 of 6 (permalink) Old 05-08-2011, 02:46 AM Thread Starter
Maroon truck guy
I have it tore down beyond using the starter. I was going to try the crank.
post #6 of 6 (permalink) Old 05-08-2011, 03:10 AM
Silverback's Avatar
I was refering to bumping the motor over manually by using the starter wire on the passenger side with the key OFF my bad. And of course turning it over manually works too.
[email protected]
