Fuel system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 05-07-2011, 07:10 AM Thread Starter
doofpowerstroke's Avatar
Fuel system
i am in need of a fuel system for an 06 powerstroke if anyone has any ideas or one laying around let me know please
2006 EXT CAB LB F350
S 300 62/80 non vgtFOR SALE
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
5 Inch Straight Pipe 8" Tip
325/65/18 Firestone MTs
XDP Sump
Coolant Filter
4 Piller Glowshift Gagues
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
doofpowerstroke is offline
post #2 of 22 (permalink) Old 05-07-2011, 12:04 PM
Extended Power's Avatar
Re: Fuel system
My Aeromotive fuel pump is for sale in the "For Sale" section, under the title: "Lots of stuff for sale".
For the Ultimate fuel system, you need:
Hellman sump
DAHL 200 fuel/water separator/filter
Aeromotive Marine grade pump
Aeromotive filter after the pump
Aeromotive Marine grade regulator
Y-block
Fuel cooler
Fuel pressure gauge
check valve in the return line.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #3 of 22 (permalink) Old 05-08-2011, 03:50 AM
new2deisel's Avatar
Re: Fuel system
I am in the same boat too. Installed a fuel pressure gauge and at idle or cruising it sits about 61psi. At wide open throttle it can drop close to 40psi for a split second. I need a good cheap fuel upgrade. I already did the blue spring and 6.4 banjo bolts.
new2deisel is offline
post #4 of 22 (permalink) Old 05-08-2011, 04:07 AM
<-•DEISEL CRAFT•
coalroller3x's Avatar
Re: Fuel system
Shoot I just sold a air dog 150 I took off of a truck . Extended power is a good guy to buy off of. I give him props.
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #5 of 22 (permalink) Old 05-08-2011, 12:11 PM
Re: Fuel system
Thank You!
post #6 of 22 (permalink) Old 05-08-2011, 02:20 PM
I dont know
Re: Fuel system
Add a 100.00 Walbro inline with stock. Upgrade to 6.4 banjos. If you feel like it throw in a regulated return.
o4 RC six speed.
6.0 six speed is offline
post #7 of 22 (permalink) Old 05-08-2011, 07:39 PM
burning mine saving yours
RocknRoll's Avatar
Re: Fuel system
61psi isn't bad is it?
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
RocknRoll is offline
post #8 of 22 (permalink) Old 05-08-2011, 08:05 PM
Banned
Smut's Avatar
Re: Fuel system
hell no
Smut is offline
post #9 of 22 (permalink) Old 05-08-2011, 08:19 PM
Attention Whore
UNBROKEN's Avatar
Re: Fuel system
Our search feature is pretty good...you should give it a shot.
Peruse these threads for ideas....
PowerStrokeNation - Search Results
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
post #10 of 22 (permalink) Old 05-08-2011, 09:13 PM
07_powerstroke's Avatar
Re: Fuel system
Hellman sump
Y-block
Fuel cooler
Fuel pressure gauge
How much does all this cost roughly? Also where is a good place to purchase it?
07 ford f250
Josh Vandyke
07_powerstroke is offline
