wireing HPOP gauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-07-2011, 01:56 AM Thread Starter
strokin6L's Avatar
wireing HPOP gauge
I'm gonna be having a HPOP gauge made from Dakota Digital and just ordered a HPOP pigtail harness to the ease of wiring this gauge instead of cutting and tapping into the harness itself. Is there only one wire to hook up or two? Here's the Strictly Diesel pigtail harness i ordered and it says that there are two wires(blue and grey), just wondering.
Driven Diesel HPO Gauge Pigtail
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #2 of 10 (permalink) Old 05-07-2011, 03:44 AM
379cat's Avatar
Re: wireing HPOP gauge
Wow that's cool iv never seen that before... so you you use the factory sensor for the sender?
99 ford superduty started its life with a 5.4 triton, now its got a 05 6.0 powerstroke in it , BD thruster turbo, RCD 175 cc injectors, ARP studs, black onyx gaskets inovative tunes. homade egr delete. homade RR fuel system fass 150 pump, suncoast trans kit ran 13.4 fuel only
379cat is offline
post #3 of 10 (permalink) Old 05-07-2011, 04:48 AM
Wide Open
AzPsd55's Avatar
Thats the same pigtail I used, all you need to do is find the positive wire from your gauge mine was blue but they were auto meter, and hook it up to the purple wire from the pig tail, then hook up power and you should be good.
Gary-
00 F250 ccsb 2wd,
Intake AFE big boost
Exhaust Diamond eye
Reg ret, Fuel bowl delete 5/8 pickup
Pre, post filtration
Sinister overboost
GTX4294r 1.15 div on Irate mount
Turbo smart 45mm wast gate
Billit intake plenums
Fuelab pump
ARP studs
Smith bro push rods
Comp 910's
Beans tuning
Gauges
Srp1
AzPsd55 is offline
post #4 of 10 (permalink) Old 05-07-2011, 03:00 PM
Dakota would have to answer that for 100% certainty. Depending on the internal gauge circuitry, it could just be looking for the 0-5V ICP output(1-wire) to base it's display readings on.
william_04_x is offline
post #5 of 10 (permalink) Old 05-07-2011, 05:56 PM Thread Starter
strokin6L's Avatar
already talked to them about it. They've already made some HPOP gauges for someone and still have the info. All they needed to know is 0psi at 0 volts and 4000psi at 5 volts. All i gotta do is hook the sender wire up from the gauge to the volt wire on the harness and it's good to go.
post #6 of 10 (permalink) Old 05-07-2011, 05:56 PM Thread Starter
strokin6L's Avatar
yup
post #7 of 10 (permalink) Old 05-08-2011, 02:36 AM
<-•DEISEL CRAFT•
coalroller3x's Avatar
How much was gauge and can u post some pics up I'm curious
Thanks beo
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #8 of 10 (permalink) Old 05-08-2011, 07:59 PM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
I don't get the point of an HPOP gauge. I mean, if the HPOP dies, the truck wont run... seems like the gauge is just there to laugh at you.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
post #9 of 10 (permalink) Old 05-09-2011, 01:22 AM Thread Starter
strokin6L's Avatar
a HPOP is good to see how much PSI the pump is putting out. Usually is gets weak before it dies. So by monitoring your HPOP you can tell if your HPOP is in good shape or if it is weak by lower than normal PSI, or possibly a leak in the system.
post #10 of 10 (permalink) Old 05-09-2011, 02:07 AM Thread Starter
strokin6L's Avatar
Thanks beo
I haven't gotten the gauge yet. It is $150. The gauge will be programmed to have a pre-set low limit at 400psi and pre-set high limit set at 4000psi they told me. The display is going to be a x10 factor...so if the display reads 50, the actual psi is 500, and a reading of 350 will be 3500. I already have the pyro and boost gauge in the new quad pod. So hopefully by next week i'll have time to get them in once i get the trans, fuel, and HPOP. Here's what the dakota digitals look like if you haven't seen them.
Individual Instruments
I have the ones that have the teal display with chrome bezels. I'll get some pics as soon as i can.
