TURBO OIL FEED & DRAIN TUBE - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-04-2011, 12:21 AM Thread Starter
WCH_diesel's Avatar
Dose it help to get the oil feed and drain tube,what dose it do and can you tell a difference?
WCH_diesel is offline
post #2 of 9 (permalink) Old 05-04-2011, 12:30 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: TURBO OIL FEED & DRAIN TUBE
wtf
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #3 of 9 (permalink) Old 05-04-2011, 12:32 AM
If you are removing your turbo from the pedestal, you will need the "turbo hardware" kit which includes the o-rings for the oil drain tube and three new turbo-to-pedestal bolts and a new paper gasket for the oil supply line connection to the turbo.
There is a new(er) turbo oil supply line that is a solid line, no more stainless steel flex joint. If your turbo oil supply line has the flex joint, you should replace it.
The new(er) turbo oil drain tube has a smooth bend in it. The older one had a bad bend (with a slight kink) which created a small restriction.
What they do is, as their name implies. The turbo oil supply line is the skinny line that goes to the top of the turbo. The oil flows from the top down. The oil drain tube sits on the pedestal and is inserted into the bottom of the turbo. The other end of the drain tube is inserted into the HPOP cover. There are o-rings on both ends of the drain tube. When installing the turbo drain tube, do not insert the tube deeper than .9 inches into the HPOP cover. If you do that, remove the drain tube and replace that o-ring and try again. The o-ring can catch on a lip on the HPOP cover, nicking it. That would cause a leak.
'06 F-350 6.0 Excab short box 4X4 Lariat FX4
Bulletproof oil cooler w/cold weather package, blue spring, EGR delete, CCV mod, edge insight and autometer gauges
NYC F-350 is offline
post #4 of 9 (permalink) Old 05-04-2011, 12:34 AM
Smoke Blowin Stroker
Kountryboy 6.0's Avatar
Send a message via AIM to Kountryboy 6.0
If your talking about the upgraded ford feed and drain tubes you wont be able to tell a difference but your turbo will thank you for it. It lets more cooling/lubricating oil in and out of the turbo quicker.
2005 F250 casserly 190 sticks,VGT-ss,SCT X3,ARP studs,S&B intake,ITP regulated return,airdog 150,sinister egr delete,4 inch exhaust into a 6 inch mitre cut,running innovative extreme street as a DD with moderate innovative ficm tuning
Kountryboy 6.0 is offline
post #5 of 9 (permalink) Old 05-04-2011, 12:39 AM Thread Starter
WCH_diesel's Avatar
where is a good place to get them
post #6 of 9 (permalink) Old 05-04-2011, 12:43 AM
In The Passing Lane
SSpeeDEMONSS's Avatar
probably from ford.
Garrett
2003 F-250 6.0 XLT CCSB 4WD 5R110- rebuilding it
1994 2500 12v RCLB 4WD 5spd- 382hp/1000tq gone but not forgotten
2000 GMC 2500 6.0 LQ4 4l80e RCLB 2wd
- stock
SSpeeDEMONSS is offline
post #7 of 9 (permalink) Old 05-04-2011, 05:38 AM
sesco4's Avatar
I ordered mine from Tousley Ford they have really good prices in there parts.
sesco4 is offline
post #8 of 9 (permalink) Old 05-04-2011, 01:39 PM Thread Starter
WCH_diesel's Avatar
what did they have the part name as cause i cant find them on there web site
post #9 of 9 (permalink) Old 05-04-2011, 04:35 PM
Pitbull-Powerstroker
The part names are in your thread title. Just call Tousleys and they'll be able to help you out no problem
04 2wd 6.0 , with all kinds of overpriced stuff added and deleted ..
Loonatic is offline
