05 Injector problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 05-01-2011, 04:20 PM Thread Starter
05 Injector problem
Is there a write up on the proper way to change an injector here some where? If there is could someone point me in the right direction please? The no.3 injector is bad and I don't want to make the problem worse.
les-or-more is offline
post #2 of 21 (permalink) Old 05-01-2011, 06:47 PM Thread Starter
Re: 05 Injector problem
Bump anybody?
post #3 of 21 (permalink) Old 05-02-2011, 04:37 PM Thread Starter
Is there something I absolutely should not do, our local ford dealer went belly up last year, so any help would be appreciated.
post #4 of 21 (permalink) Old 05-03-2011, 12:59 PM Thread Starter
Chirp chirp hey who turned out the lights!!! chirp chirp
Boy this is a tough crowd
post #5 of 21 (permalink) Old 05-03-2011, 01:03 PM
I Just Break Stuff
Guess I missed this one. No. 3 isn't that bad. It's in the front. What brings you to changing that one injector. Symptoms????
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #6 of 21 (permalink) Old 05-03-2011, 01:22 PM Thread Starter
Started running rough, I took it to a local shop they scanned it and said no.1 had no contribution. So I found a guy to change it but that didn't fix it. Then it threw an EGR code so I deleted that it was still running rough so I took it to the closest ford dealer and they told me to change no 3.
As far as symptoms it has a skip at idle, starts hard and smokes on start up and the worst one is when it shifts to fifth it bucks like crazy unless its turning over 2k.
post #7 of 21 (permalink) Old 05-03-2011, 01:33 PM
I Just Break Stuff
Yup, sounds about right. Anyway, just remember everything gets a new oring. Coat injector orings with fresh oil. Use a 9mm deep socket to install your copper washer on the tip. 19mm socket gets the electrical connector out of the rocker box. Just put the open end over the connector and give it a thump with the palm of your hand. They pop right through. Short ratchet wrenches come in handy to get the valve cover off. The 6.0 bible is full of torque specs. You can find it in the 6.0 tech section. At the top. That's about it. The fun part is getting there. Swapping it is the easy part.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #8 of 21 (permalink) Old 05-03-2011, 01:39 PM Thread Starter
I read somewhere about pulling the glowplug to prevent hydrolocking, but I don't know where I saw it. Does this apply?
post #9 of 21 (permalink) Old 05-03-2011, 01:47 PM
I Just Break Stuff
I don't, I just pull em quick. Keep raggs handy. Remember to make sure you cup is clean. Check for cracks and such. Don't think you will have that problem, but you never know.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #10 of 21 (permalink) Old 05-03-2011, 01:58 PM Thread Starter
Ok, thanks!
