SRL ++ Dyno and gearhead tune reviews :) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 04-29-2011, 10:32 PM Thread Starter
Hey guys I dynoed my Truck at St. Joe Diesel. They are a really good diesel shop in the midwest and do a lot of big builds
My truck put down 423HP and 753TQ on a Dynocom dyno. This was running my SRL ++ studded tune. When you look at the dyno it shows 436hp, but that was when it shifted so if you look at the the second it picture it shows I made 423 at 3400rpms. When we dynoed we put it in tow/haul and hit at about 50mph when the converter was locked in 4th and it would hit 26/26lbs boost.
All I can say is this SRL++ halls and it shifts really nice. It runs a little more boost all the time compared to the SRL tune. Running this tune gives me a little over 15mpg mixed. I can hit 29lbs if I roll into it at 70mph.
The SRL tune is about the same but just cruising it will run 8 or 9lbs of boost where the ++ runs about 10 or 11lbs running around 70mph. I usually get around 16-17 mixed with this tune. I can hit 26lbs if I roll into it at 70mph.
The 8k lbs tow tune works great. I have towed about 7klbs with it and never went over 1000deg. I did up the shift pressure by 10% for firmer shifts. I get the best mpg with this tune...about a solid 17mpg and sometimes 18 with mostly highway.
All in all I am very happy with my gearhead tunes and Matt was real good to work with.
2007 F250 CC Lariat
Black Onyx Head Gaskets (1st time)
Studded and trans built by BTS
Sinister EGR Delete & Coolant filter
Powermax Turbo
Edge insight CS W/Pyro & Fuel Pressure
MBRP 4" Straight pipe
423RWHP 753RWTQ
sly1types is offline
post #2 of 21 (permalink) Old 04-29-2011, 10:45 PM
Administrator
Zmann's Avatar
Re: SRL ++ Dyno and gearhead tune reviews :)
Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 21 (permalink) Old 04-30-2011, 01:12 AM
psn local
cool good review. did you drop fuel pressure? this means the slr++ has identical power to the Xtreme race.
smokin6.0psd is offline
post #4 of 21 (permalink) Old 04-30-2011, 01:49 AM
his tune is nice but it just down shifts to quick before hitting any boost above 18-20 psi
2005 6.0 CC SB 4x4
Special thanks to Doug at GoGoDiesel
4x4freak is offline
post #5 of 21 (permalink) Old 04-30-2011, 05:39 PM
Reppin' the 6.4L
SickStroke6.0's Avatar
BTW, the SRL+ may have netted you more power, have you ever tried running that tune? The SRL++ is only for trucks that won't hit 30 PSI on the regular SRL+. If it hits 30 PSI on the regular SRL+ tune, your SRL++ will actually be slower/less powerful.
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
post #6 of 21 (permalink) Old 04-30-2011, 06:41 PM
I Just Break Stuff
That sounds about right. I can't run ++. Hits over 40psi. Whoops. Hangs at around 32 with the +.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #7 of 21 (permalink) Old 04-30-2011, 07:38 PM
Reppin' the 6.4L
Yep, the SRL++ will boost some crazy numbers on some trucks. With boost that high the turbo isn't as efficient.
Blake
post #8 of 21 (permalink) Old 04-30-2011, 08:21 PM
I Just Break Stuff
That's with a powermax. Got updated tunes after the turbo swap. Could hear that poor turbo skareemin. Nope, backed it on down. No sense making hot air and killing a turbo.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #9 of 21 (permalink) Old 05-01-2011, 01:00 AM
Reppin' the 6.4L
Even with a stock turbo, the SRL++ will hit outrageous umbers close to 40.
Blake
post #10 of 21 (permalink) Old 05-01-2011, 01:27 AM
Twan's Avatar
Is 40psinto much for the power max? I thought I seen people running 50psi with 190's?
2006 CCLB 4x4 King Ranch 2"lift 35's, S&B, sct tunes by Innovative, Quick Tricks, Powermax, 6.4 Banjo bolts, coolant filter, edge insight, 4" turbo back.
Twan is offline
