please tell me it isn't this again... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-28-2011, 02:22 PM Thread Starter
09 6.4
webb06's Avatar
i blew HG's about 5k miles ago and replaced them and put studs in it. the heads were decked and everything was done like its supposed to be done. then this passed week my heat has started screwing up again, when cruising down the road it will blow nice and hot, but when i pull up to a stop light after about 5 seconds it begins to blow nothing but cold air!!! im hoping that this isnt HG's again because the first time they blew the heater would do great at stop lights but would blow straight cold air when cruising so it is pretty much the exact opposite now! i have the coolant just under the minimum mark on the overflow tank. anyone have any ideas on what the he11 is going on? please just dont tell me its HG's again haha!!!
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #2 of 10 (permalink) Old 04-28-2011, 02:37 PM
Banned
Re: please tell me it isn't this again...
If you're holding coolant why would you suspect hgs? I'd look elsewhere, I don't think your heater problem is head gasket related
donzimama is offline
post #3 of 10 (permalink) Old 04-28-2011, 02:47 PM
<sideways skyscraper
Silverback's Avatar
Lol...you got coolant in the bottle? Any signs of puking? Overheating? Sounds like a blend door issue. Take it easy
06 CCLB 8" lift 37s 22s 8300#
[email protected]
Silverback is offline
post #4 of 10 (permalink) Old 04-28-2011, 03:20 PM
I understand 6.0 waterpumps have plastic impellers that are known to crack. Symptoms would be as you describe. What is you coolant temp?
lenzhotrod is offline
post #5 of 10 (permalink) Old 04-29-2011, 02:25 AM Thread Starter
09 6.4
webb06's Avatar
if the coolant is filled to the max line on the bottle then it will def. puke it out to where it sits now. i dont have a coolant temp gauge except the one in the dash and it stays dead center when running. i was just expecting the worst and hoping for the best haha!! so should i lean towards the water pump being the problem?
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #6 of 10 (permalink) Old 04-29-2011, 05:08 AM
<-•DEISEL CRAFT•
coalroller3x's Avatar
Dude chill out
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #7 of 10 (permalink) Old 05-01-2011, 03:19 AM
Black Stroker
whytry's Avatar
Originally Posted by coalroller3x View Post
Dude chill out
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
whytry is offline
post #8 of 10 (permalink) Old 05-01-2011, 03:34 AM
Redneck6.0L's Avatar
check the valve in the heater line by the alternator
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #9 of 10 (permalink) Old 05-01-2011, 05:30 AM
I had the same problem, some heat when driving but cold at stop's. Changed the Thermostat and everythign is fine now! It was sticking open about 1/8 inch... Hope this helps.
Harley_Wrench is offline
post #10 of 10 (permalink) Old 05-02-2011, 01:25 AM
motoxracer42's Avatar
vac line to the valve on by the alternator or the valve itself lol. people always knock that line off.
06 crew cab
06 reg cab
motoxracer42 is offline
