Fuel pressure gauge install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-28-2011, 02:18 AM Thread Starter
new2deisel's Avatar
Wondering wear everyone is installing the sending unit on there 6.0? Is the adapter from Strickley Diesel needed?
new2deisel is offline
post #2 of 14 (permalink) Old 04-28-2011, 02:48 AM
strokin6L's Avatar
Re: Fuel pressure gauge install
it's alot easier if you do use it. Here's a pic of mine. I used the ITP(strickly diesel) fuel pressure adapter line on my aeromotive fuel pressure regulator. It comes with a fitting that'll screw into the factory fuel pressure regulator cover. Makes it easy IMHO.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #3 of 14 (permalink) Old 04-28-2011, 03:00 AM
07_powerstroke's Avatar
I got mine from sinister diesel
07 ford f250
Josh Vandyke
07_powerstroke is offline
post #4 of 14 (permalink) Old 04-28-2011, 06:25 AM
No the adapter is not need but it keeps the sender away from the heat and viberation of the motor.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #5 of 14 (permalink) Old 04-28-2011, 11:48 AM
Dieselpower84's Avatar
I installed mine in the service port at the fuel bowl. Friend made me an adapter and bought the SS braided line from Diesel Manor. I believe I saw the adapter on Diesel Manor's website as well.
2007 F-250 Super Duty Lariat with 4" MBRP turbo back exhaust, ARP studs, Black onyx head gaskets, Sinister Mfg. EGR delete, 20" Rockstar wheels, 37x13.50x20 Interco M16 tires, 6" ProComp suspension lift, Diablosport Predator, Quad gauge pillar w/ Autometer gauges.
Dieselpower84 is offline
post #6 of 14 (permalink) Old 04-28-2011, 12:33 PM
Administrator
Zmann's Avatar
An adapter is needed it's metric threads to NPT (american)
m12 1.5 male oring to female 1/8 npt
and the adapter with the hose helps if your sender is big or sensitive to heat /vibration
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 14 (permalink) Old 04-28-2011, 01:57 PM Thread Starter
new2deisel's Avatar
I ended up getting the one from Strickly Diesel. Anyone know if it has a plug for the tee? I dont plan on putting a gauge under the good at this time.
post #8 of 14 (permalink) Old 04-28-2011, 03:40 PM
PETE ENGR PSD
The T should have the line come in from your housing, and on the opposite side I believe its left open for a gauge sender to be screwed into. The other part of the T is capped. I think its for an electronic gauge
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #9 of 14 (permalink) Old 04-28-2011, 04:46 PM
strokin6L's Avatar
there is only one opening on the T...and it's for the sending unit. The top part is the schrader valve to bleed off any air that might be trapped in the line.
post #10 of 14 (permalink) Old 04-29-2011, 07:17 PM
I couldnt find the correct adapter so I made one then the dang sending unit wouldnt fit and got the kit from strictly and all was well!!
Eric
05 F350 CC LB 4x4
Lifted, exhaust, intake, gauges, SCT
EPDP99 is offline
