Shift Flare - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-28-2011, 12:04 AM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
Shift Flare
Noticed a slight flare in shifts 3-4 under WOT. Is this a symptom of other problems or is my trans just not able to keep up with mods? Is the direct solenoid the fix for this?
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 18 (permalink) Old 04-28-2011, 12:36 AM
i like to party
pizza pig's Avatar
Re: Shift Flare
what tunes do you have?
pizza pig is offline
post #3 of 18 (permalink) Old 04-28-2011, 01:05 AM
07_powerstroke's Avatar
Re: Shift Flare
For the $100 for the solenoid I would just def try and see if it fixes it. Also it wouldnt be a bad mod to have.
07 ford f250
Josh Vandyke
07_powerstroke is offline
post #4 of 18 (permalink) Old 04-28-2011, 01:17 AM Thread Starter
BRING DA AMBALAMPS
Re: Shift Flare
well i'm going to do it but just wondering if that's the "fix" or a patch for other problems...
post #5 of 18 (permalink) Old 04-28-2011, 02:36 AM
Reppin' the 6.4L
SickStroke6.0's Avatar
Re: Shift Flare
Doug's Solenoid works to fix the 3-5 shift, so that just might fix it up for ya.
Blake
Looking for a second 6.4L....
2008 F-250 CCSB King Ranch 6.4L
4" Rough Country Lift, Dual Steering Stabilizers, 20x10" XD Diesels, 35x12.50x20" Mickey Thompson MTZ's, Line-X, 15% Tint, MBRP 4" Cool Duals w/ 6" Tips, S&B Intake, Flo-Pro EGR Delete and Elbow, MBRP CAC Tube
SickStroke6.0 is offline
post #6 of 18 (permalink) Old 04-28-2011, 02:37 AM
strokin6L's Avatar
Re: Shift Flare
got doug's modified direct solenoid...had it for over a month. Gotta try to get this thing in. I tent to have a small 2-3 shift flare once in a while. Happens on all tunes, but fine when stock. Got all shift pressures raised to 25%. Maybe the 2-3 shift in each tune needs tweeking.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #7 of 18 (permalink) Old 04-28-2011, 03:11 AM Thread Starter
BRING DA AMBALAMPS
Re: Shift Flare
I've got all my shift pressures up 20%. I'll bump 3-5 another 5% and see if that helps until I get a solenoid.
post #8 of 18 (permalink) Old 04-30-2011, 12:44 AM
TimmyaleX
Re: Shift Flare
what is a shift flare?
Support Blue Collar Workers
-2008 F-350 XLCCLBSRWZF6
-Fast Idle Switch
-5" DP back
-Innovative livewire
-No Limit
-Newton Fat Boy Traction Bars
-Ebay Leveling Kit
-ICON adj. Trac BAr
-NITTO Terra Grapplers
-Flo Pro EGR delete
-South Bend 3250
-Spartan
-Lab Pit "Stella"
HD-tech-NH is offline
post #9 of 18 (permalink) Old 04-30-2011, 01:18 AM
strokin6L's Avatar
Re: Shift Flare
it's when a shift takes longer than it should to shift into the next gear.
post #10 of 18 (permalink) Old 05-02-2011, 02:23 AM
bwstone92's Avatar
Re: Shift Flare
had the problem for the first time after i threw in idp x street, i think it was shift 4 to 5 though
04 Harley Davidson F-350 6.0
-05 Harley makeover
2010 Harley Davidson F-350 6.4
bwstone92 is offline
