Raptor Fuel pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-26-2011, 02:07 AM Thread Starter
doofpowerstroke's Avatar
Raptor Fuel pump
is anyone on here running a raptor as a pusher pump any help would be nice i am kinda lost on this a buddy that is running a cummins got an airdog and gave me the pump i need to use it as a pusher pump becasue i got new 155cc injectors.
2006 EXT CAB LB F350
S 300 62/80 non vgtFOR SALE
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
5 Inch Straight Pipe 8" Tip
325/65/18 Firestone MTs
XDP Sump
Coolant Filter
4 Piller Glowshift Gagues
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
doofpowerstroke is offline
post #2 of 18 (permalink) Old 04-26-2011, 07:43 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: Raptor Fuel pump
IIRC you will run it pre-HFCM. I'd suggest a fuel sump/pickup tube as well.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 18 (permalink) Old 04-27-2011, 05:26 AM Thread Starter
hfcm? and u are saying redo the tube in my tank and ####
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #4 of 18 (permalink) Old 04-27-2011, 02:58 PM
If the Raptor is a 10 psi unit (which it more than likely is) then you will have to run that before your stock high pressure pump. I think he is suggesting that you modify your stock pickup to draw more fuel. Which would usually mean installing a draw tube or something like a Hellman sump.
IMO just stick with the draw tube, most people don't need a bottom sump unless they are needing massive amounts of fuel. When installed properly the draw tube will never have any issues.
Kyle
(317) 421-3180 x121
(573) 694-8833 cell
post #5 of 18 (permalink) Old 04-27-2011, 03:31 PM
Extended Power's Avatar
Whatever system/pump you go with...get rid of the stock pick-up tube, and any tube anyone else sells you...GO WITH THE HELLMAN SUMP!!!!
2003 F-350 KingRanch 4x4
Extended Power is offline
post #6 of 18 (permalink) Old 04-27-2011, 03:33 PM
6.0 money pit
smokinstroker's Avatar
or a tsd sump.
smokinstroker is offline
post #7 of 18 (permalink) Old 04-27-2011, 05:24 PM
strokin6L's Avatar
love my hellmans sump
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #8 of 18 (permalink) Old 04-27-2011, 06:16 PM Thread Starter
where can i get one
Fass Fuel
Warren Diesel 155's
Regulated Return
AFE stage 2 intake
XDP Sump
Coolant Filter
EGR Delete
Gearhead Tuning
Swamps 58v FICM
Head Studs ARP
post #9 of 18 (permalink) Old 04-27-2011, 06:22 PM
Tsd has their own give one of the Chris' a call
patrickke is offline
post #10 of 18 (permalink) Old 04-27-2011, 06:31 PM
I have thought of getting the raptor also. I do not want to spend $600 on a new airdog pump.............
smokersteve is offline
