6.4 internals in 6.0? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-26-2011, 12:43 AM Thread Starter
suprdzlduty's Avatar
I thought I remembered reading a post on this but I cant find it. I think Captain Negativity had mentioned something on it...I know a 6.4 block is a twin to a 6.0 by looking a the outside...is the deck hieght any different or is it all in the rods, pistons and crank? will a 6.0 intake manifold fit on a 6.4? if so then the 6.4 deck should be the same??? anybody ever looked into this?
04 CCSB Lariat, 4x4, studded & deleted(Elite), Garrett stage 1(DI), Innovative tunes, DS coolant filter, FS2500, Banks intercooled, 17x9 MT classicII's, Nittos, trans rebuilt by me, B&M shift kit, billet converter...sold
04 F450 RC studded & deleted(FCDP), alum. wheels, pulls the gn.
05 build in progress...
suprdzlduty is offline
post #2 of 4 (permalink) Old 04-26-2011, 12:49 AM
WINNING
Countryboy07's Avatar
Re: 6.4 internals in 6.0?
I'd talk to the guys at MPD, they seem to be doing some good stuff with both the 6.0's and the 6.4's
2002 VW Jetta TDI
Countryboy07 is offline
post #3 of 4 (permalink) Old 04-26-2011, 01:01 AM
strokin6L's Avatar
I believe FCDP is running a 6.4 intake manifold on their ranger drag truck. So i would think that a 6L intake manifold would fit on a 6.4
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #4 of 4 (permalink) Old 04-26-2011, 02:36 PM
lubeowner's Avatar
The 6.4 block is different in the webbing up on top of the motor. You can't interchange blocks as the 6.4 has no provisions for oil to feed the HPO system. The pistions, rods and cranks are not interchangeable as the wrist pins and crank journals are much larger on the 6.4. You can get it done but will take lots of machining.
The intakes and exhaust manifolds are somewhat interchangeable. The 6.0 intake will not work with the 6.4 twin turbo setup. The turbos will hit the intake.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
