4" downpipe? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 04-21-2011, 03:12 AM Thread Starter
Bustedknuckles's Avatar
4" downpipe?
How many have one in thier truck and how hard was it to install? TIA
Official PSN special needs duramax guy! ASE cert. mastertech 2004 LB7, Efi-live with tunes from THE idahorob, s366 from EPR, head studs, Dmax-4 transmission kit, airdog 165, tie rod sleeves, intake, exhaust, gauges.
Bustedknuckles is offline
post #2 of 23 (permalink) Old 04-21-2011, 03:19 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: 4" downpipe?
I have a magnaflow 4" downpipe and honestly it wasn't all that bad to install. The hardest part was getting the turbo flange up and around the up-pipes. I would imagine the flange would be the same size on a 3.5" downpipe as well.
After that just some careful lining up the same you would with any exhaust and should be good to go. Its a TIGHT fit (probably less than a 1/4" on both sides at the tight spots) but it should also have a small flat spot where it passes by the bellows too.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #3 of 23 (permalink) Old 04-21-2011, 04:07 AM
Abrannan19's Avatar
Re: 4" downpipe?
Not worth the hassle and possible rubbing issues.jmo
Abrannan19 is offline
post #4 of 23 (permalink) Old 04-21-2011, 04:13 AM
BUFF's Avatar
Re: 4" downpipe?
I have a 4" flowmaster on mine. It was easy and no rubbing but it is easyer to do with two people.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #5 of 23 (permalink) Old 04-21-2011, 04:26 AM
60POWERSTROKE73's Avatar
Re: 4" downpipe?
I have a MBRP 4" DP and it was a breeze to put on.
Now the factory 3.5" DP was a pain!! Especially cause we didn't cut it.
Mine doesn't rub or anything. Nor does it viberate the floor in the cab or any where else.
As BUFF said it's easy with 2 people.
2003 F-350 Powerstroke 6.0L CC LB Lariat FX4
MBRP 4" Turbo Back- Straight Pipe Glowshift Gauges- EGT, Boost, and Trans Temp SCT X3 with Custom Tunes from Innovative Diesel 21/2" Pro Comp Leveling Kit Moto Metal 951 rims on 33" Nitto Trail Grapplers
Originally Posted by bigrpowr View Post
The 6.4 is unreliable. You want a 03-04 6.0. Best motor ford ever built.
60POWERSTROKE73 is offline
post #6 of 23 (permalink) Old 04-21-2011, 05:22 AM
Abrannan19's Avatar
Re: 4" downpipe?
MBRP doesn't offer a 4" downpipe. Its 3.5 " then steps up to 4" from the downpipe back. The stock downpipe is 3".
post #7 of 23 (permalink) Old 04-21-2011, 08:57 AM
Re: 4" downpipe?
Really? I didn't know that.
Oh well lol
post #8 of 23 (permalink) Old 04-21-2011, 11:19 AM Thread Starter
Re: 4" downpipe?
Thanks all, I'm thinking the guys who are saying it was easy don't actually have 4" downpipes because I put one on last night and it took one guy on top pulling and a guy underneath pushing and twisting with the truck on the lift. We were about to give up because the instructions said it might not fit. Getting the flange past was tricky but nothing like getting the rest in there. What a pita, you literally had to force it the whole way, now that its in its all good thoughvand sounds sweet!
post #9 of 23 (permalink) Old 04-21-2011, 12:04 PM
6Leaker
jdc753's Avatar
Re: 4" downpipe?
Meh believe it or not I can go out to my truck and take a pic on the lunch break if your interested.
Might help because the magnaflow one is a 2-piece downpipe with a clamp just after the up pipe. Little tight for the clamp but enough room to get a air ratchet in there. The second piece of the downpipe goes from just above the bed plate to just after the transmission crossmember where it connects to the cat, or uses a 4" test pipe till it jumps up to 5" just after the cat. Only place where I had issues with rubbing was on the 2nd (furthest to the back) bolt on the transmission cross member, there is only about 1" on each side when the pipe is centered in the opening there.
Just guessing the other kits don't have a 2-piece downpipe if they are causing soo much trouble. I did mine on the ground and maybe that helped push it up around the up-pipe and firewall. Only the flange gave me trouble, once it was up then the pipe was very loose, but wasn't going to fall down, and I could wiggle it all over, just had to go to the top to put the v-band clamp on and was good.
My flat spot in the upper piece isn't as prominent as in this photo, but wasn't too hard to find, is a little bigger than a half dollar coin, and just simply flat instead of an actual indent like shown above.
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #10 of 23 (permalink) Old 04-21-2011, 12:25 PM Thread Starter
Re: 4" downpipe?
I believe you, the diamond eye kit I installed looked just like that. I wonder if there's a difference in trucks or having it on the lift made it tighter? The pipe was literally so tight going in that I doubt I could get it back out without mangling it????
