HELP turbo wont come off?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-21-2011, 12:30 AM Thread Starter
workin on a 05 6.0 got all 3 bolts out for ped all v clamps out how do i remove the oil tube i belive it is the only thing left help please??????/
BDP,238S/100s,live tuned by john @ BDP,stealth hpop,comp 910s,studs,D66 wastegated, idm mod, boost fooler,3 gauge pillar,BDP dual pump fuel kit,99 IC,BTS,single stage NX kit (655 hp) 12.649 @ 110 mph.
CT SMOKER is offline
post #2 of 13 (permalink) Old 04-21-2011, 12:31 AM
07strokerftw's Avatar
Re: HELP turbo wont come off??
It can be a bitch to get off that tube.. keep working with it but be careful, and again make sure you have unbolted everything
2007 F250 ccsb Lariat
33" Nitto Terra Grapplers on stocks, SCT x3 with custom extreme tunes from IDP, Autometer gauges, zoodad air mod, "2003" turbo, carriage works billet grill layover, HID 6000k, headstuds/egr delete, 6.4 banjo fuel bolt upgrade, 4" turbo back to 7" single stack
07strokerftw is offline
post #3 of 13 (permalink) Old 04-21-2011, 12:35 AM Thread Starter
so theres a lil tab on the bottom of the tube down on the motor u just pry it out i take it
post #4 of 13 (permalink) Old 04-21-2011, 12:36 AM Thread Starter
theres only three bolts on ped holding turbo to motor
post #5 of 13 (permalink) Old 04-21-2011, 12:44 AM
<-•DEISEL CRAFT•
coalroller3x's Avatar
3 bolts turbo to pedestal 4 bolts pedestal to engine.
3 bolts oil feed tube. Oil drain tube is held in place metal tap
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #6 of 13 (permalink) Old 04-21-2011, 01:00 AM Thread Starter
can i get a good link to get turbo off
post #7 of 13 (permalink) Old 04-21-2011, 01:12 AM
suprdzlduty's Avatar
make sure the downpipe is off the turbo...use a small pry bar to push up on the turbo some...its probably hung up a little on the uppipes...its pretty easy. there is a dowel pin that sits in a notch on the back of the pedistal so you'll have to wiggle it out of there.
04 CCSB Lariat, 4x4, studded & deleted(Elite), Garrett stage 1(DI), Innovative tunes, DS coolant filter, FS2500, Banks intercooled, 17x9 MT classicII's, Nittos, trans rebuilt by me, B&M shift kit, billet converter...sold
04 F450 RC studded & deleted(FCDP), alum. wheels, pulls the gn.
05 build in progress...
suprdzlduty is offline
post #8 of 13 (permalink) Old 04-21-2011, 01:14 AM
<-•DEISEL CRAFT•
It s pretty easy pull the turbo mounting bolts (3)
Remove oil drain tube pick the turbo up off of the dowls
If you half to stick a pry bar in the cac tube outlet and pry the turbo up.
Once the turbo is off the oil drain tube should be pretty easy to remove.
05 f250
post #9 of 13 (permalink) Old 04-21-2011, 01:16 AM
<-•DEISEL CRAFT•
O if you half to wedge the up pipes out of the turbine housing be easy tho
05 f250
post #10 of 13 (permalink) Old 04-21-2011, 01:31 AM
7.3 Enthusiast
91turbogsx's Avatar
I just went through this Saturday. Once I got to the point your at now I just used a prybar and it came right off.
Just be careful on reinstallation. I swore I had the up pipe flange seated on the turbo and had the clamp tight yet had a major exhaust leak there. So ended up having to loosen the uppipes to get it perfect.
'02 F-350 4x4 Black RC/LB
4" Lift with 35's. OUO Traction Blocks
20x10 Fuel Throttle's
Lots of deleted parts...
Custom fuel system w/ Strictly Diesel RR
Dieselsite Adrenaline HPOP
DI Up-Pipes
DP-Tuned
and more...
91turbogsx is offline
