P0683 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-17-2011, 05:36 PM Thread Starter
iceman89m's Avatar
P0683
Have the glow plug module fault code P0683, Where do I start???, Is there a relay or fuse that I am missing??
03 6.0 8" Dick Cepek suspension,PJ Dirt Grip 37X14.50X16 mounted on Polished DC-1, 3 1/2" exhaust with 4" core glasspack,Frantz TP Bypass,Bullydog Triple with outlook and AEM Brute Force intake
RIP Will Iott
iceman89m is offline
post #2 of 8 (permalink) Old 03-17-2011, 09:07 PM
Komelika's Avatar
Re: P0683
Subscribed... same code two days ago. I'm searching everywhere and can't find a decent procedure to replace Glow Plugs. I need pictures. Good Luck!
Komelika is offline
post #3 of 8 (permalink) Old 03-17-2011, 11:49 PM
Marc's Avatar
Re: P0683
P0683 is a faulty glow plug controll module about 99% of the time. There is a very long pinpoint test to determine this (i have a known good one that i use to check them)....But i would say if it was my truck and i didnt have any real way of testing it, id be pretty comforatable saying that replacing the module would more than likely fix your problem
The module is the little silver box on the front of the passenger valve cover.
NHRDA Region 2 Race Director
Marc is offline
post #4 of 8 (permalink) Old 03-18-2011, 02:04 AM
Komelika's Avatar
Re: P0683
Snap! I just realized that my code is a P0673, not P0683.
Komelika is offline
post #5 of 8 (permalink) Old 03-18-2011, 02:52 AM
Marc's Avatar
Re: P0683
P0673 is cylender number three glow plug code. 90% of the time its the glow plug. Every once in a while you see a glow plug module fail on only one cylender though. Easiest way to test is to pull the number three glow plug and measure the resistance. One probe needs to go on the top little metal part that the harness snaps over....and the other one needs to to be touching the threads. Resistance should be less than 1 ohm. If the glow plug is bad, replace it. If it is good, its probably the module (its rare to see a wiring issue but its always possible.)
Marc is offline
post #6 of 8 (permalink) Old 03-18-2011, 04:14 AM
DieselStroke's Avatar
Re: P0683
Make sure you get the correct size glow plug, they changed length in between the years, putting the wrong size in will definetly not be good!!!
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
DieselStroke is offline
post #7 of 8 (permalink) Old 03-18-2011, 01:39 PM
Komelika's Avatar
Re: P0683
Its getting warmer here so the glow plugs shouldn't effect starting for a while. I'm thinking about waiting until the fall and just replacing all the glow plugs at the same time. I'd hate to replace one and have another fail shortly after. If I replace all of them then hopefully I will get another 100K out of them before having to worry again. Just have to drive around with a check engine light on until then. We'll see.
Komelika is offline
post #8 of 8 (permalink) Old 11-04-2015, 12:26 AM
Re: P0683
I know old post but I have same problem is it safe to drive
asphaltmn79 is offline
