I installed my airdog 2 yesterday with a hellmann sump.. followed the instructions as on airdog sheets.. I capped off the oem supply line on top of the tank and left the grey line connected due to the sump. all other lines reconnected. do not observe any leaks.. poured fuel in airdog filter like instructions stated... now go to start and it just cranks and cranks, no fuel pressure, pump is running..
any ideas? I know there is fuel, i disconnected fuel line @ sump and had fuel, other than that all I know is the airdog has power..
do I need to bleed the system, if so how do I do that?
On the airdog harness I did leave the 2nd plug(one other than the airdog power) and the 2 female connections in the engine compartment disconnected from anything as I thought the were extra?
