6.0 Wont Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 04-19-2010, 05:35 PM Thread Starter
kyle50131709's Avatar
6.0 Wont Start
Its a 04 has 101,000 miiles on it. it wont start. it has fresh oil and filter.also a new fuel filter. trys to start on the first time when it turns over but after that it seems like it has no fire. any info would help. thanks
kyle50131709 is offline
post #2 of 33 (permalink) Old 04-24-2010, 08:06 PM
Re: 6.0 Wont Start
I had the same problem. Its probably your FICM has died. Its pretty expensive part to replace but there is a few forums that explain how to test it. its located on the driver side valve cover.
tpohlmann is offline
post #3 of 33 (permalink) Old 04-24-2010, 10:20 PM
"resident smarty pants"
Re: 6.0 Wont Start
A no-start can be one of MANY possible things. Here is a troubleshooting guide to help find the problem:
Troubleshooting a No-Start condition - Ford Truck Enthusiasts Forums
Mark
bismic1 is offline
post #4 of 33 (permalink) Old 04-24-2010, 10:55 PM
Damnkids Motorsports
Mdub707's Avatar
Send a message via AIM to Mdub707
Re: 6.0 Wont Start
Is it getting fuel? Take the filter off on the motor and turn the key, see if the bowl fills up.
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
Mdub707 is offline
post #5 of 33 (permalink) Old 04-25-2010, 10:03 PM
PETE ENGR PSD
Re: 6.0 Wont Start
Oil pressure building on the gauge?
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #6 of 33 (permalink) Old 04-26-2010, 04:14 AM
Re: 6.0 Wont Start
Being an 04 and what i've seen in the past year id say your cam position sensor is bad $30-50 at the dealer and a half an hour to install. Before you invest a ton of money throwing parts at it find someone with a scanner or buy your self auto enginuity and find out what exactly is wrong. auto enginuity is like $350
halerazor is offline
post #7 of 33 (permalink) Old 06-06-2010, 01:26 AM
Re: 6.0 Wont Start
kyle50131709 - im having the same problem with my 06. Ran fine one day wouldnt start the next. Have you had any luck?
shawn0075 is offline
post #8 of 33 (permalink) Old 06-06-2010, 01:56 AM
suprdzlduty's Avatar
Re: 6.0 Wont Start
did you bleed the air from the fuel system(the top filter) if not then that will cause a no start due to a air lock. loosen the top fuel filter cap and turn the key on to activate the fuel pump. helps if you have some help so that you don't spill fuel everywhere. thats where I would start. hope that helps.
04 CCSB Lariat, 4x4, studded & deleted(Elite), Garrett stage 1(DI), Innovative tunes, DS coolant filter, FS2500, Banks intercooled, 17x9 MT classicII's, Nittos, trans rebuilt by me, B&M shift kit, billet converter...sold
04 F450 RC studded & deleted(FCDP), alum. wheels, pulls the gn.
05 build in progress...
suprdzlduty is offline
post #9 of 33 (permalink) Old 06-15-2010, 09:14 PM
Re: 6.0 Wont Start
its very easy to test the ficm, theres a lil cap that comes off with two allens. Soon as you take the cap off you will need a volt meter. If you have a 4 pin ficm Test the pin closer to the fender and should read 70 volt i believe? Then have someone start the truck, if your voltage drops will cranking you have a bad ficm
ibidu1 is offline
post #10 of 33 (permalink) Old 07-02-2010, 08:30 PM
Phdruss
Re: 6.0 Wont Start
Did you ever get it running? Just happened to me. I have an 05. Apparently the 04 and 05 models had a design flaw in the High Pressure Oil Pump system. Any leak in the system tells the engine to shut down or not start. Very labor intensive. My job is $1,450.00. Had a crack in an oil libe and two leaking seals. My truck only had 40,000 miles but is a few months beyond the five year mark so no warranty.
Go to: Office of Defects Investigation (ODI), File A Safety Complaint and file a complaint against Ford. If we all do so NHTAS may issue a recall and force Ford to cover repairs.
Phdruss is offline
