6.0 Excursion Oil Light coming on - PowerStrokeNation : Ford Powerstroke Diesel Forum
 8Likes
  • 2 Post By bismic1
  • 1 Post By bismic1
  • 2 Post By matthewd11
  • 1 Post By bismic1
  • 1 Post By bismic1
  • 1 Post By Turd-250
post #1 of 9 (permalink) Old 10-30-2019, 12:52 AM Thread Starter
EA - Eggfarts Anonymous!
Turd-250's Avatar
Alrighty! I think this might be a fun one lol!
My cousins 6.0 has the check gauge light coming on and the oil pressure dummy needle falling to 0 kinda randomly when it's around idle rpm. Just started today. This was at operating temp. Runs fine tho.
It's an 04 excursion. Somewhere around 200k miles. I'll try to update with mileage and build date if he can get those details back to me.
It's pretty much stock. It did have some injectors and ficm replaced a while back. It was regularly maintained as well. They're on the red river, kinda warm, so I think it's had conventional 15w40 it's whole life. Light duty vehicle for the most part I think.
What do I need to ask him?
Oh yeah, lol, he said the and light was on at some point... just to muddy the water
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #2 of 9 (permalink) Old 10-30-2019, 12:55 AM
"resident smarty pants"
Re: 6.0 Excursion Oil Light coming on
Ask him to remove the oil filter and crank the engine to fill the oil filter housing. Post up how long it takes to fill. Should be about 8-10 seconds without closing the drain valve. If it fills quickly enough, it is probably the pressure switch.
Getting the codes read is not ever a bad idea either.
Turd-250 and Dustybumpers like this.
Mark
bismic1 is offline
post #3 of 9 (permalink) Old 10-30-2019, 01:14 AM Thread Starter
Turd-250's Avatar
Gah I fell stupid, I've read you posting that at least 2 other times lol
Turd-250 is offline
post #4 of 9 (permalink) Old 10-30-2019, 01:47 AM
lol! .
Turd-250 likes this.
Mark
bismic1 is offline
post #5 of 9 (permalink) Old 10-30-2019, 02:40 AM
matthewd11's Avatar
Took the words out of my mouth once again bismic
bismic1 and Turd-250 like this.
matthewd11 is offline
post #6 of 9 (permalink) Old 10-30-2019, 02:47 PM
Just to add -
Crank w/ the key out using the starter solenoid wire:
Locate the wire to the starter solenoid (yellow with light blue striped colored wire adjacent to the passenger side battery in the engine compartment, near the vacuum pump - it has a "squeeze-and-pull" type connection) ..... you can unplug it and get it to reach the positive battery terminal and crank that way.
You don't want unneeded glow plug operation and definitely don't need the engine to try to start!
Video showing the use of this wire to crank:
Mark
bismic1 is offline
post #7 of 9 (permalink) Old 10-30-2019, 02:52 PM Thread Starter
Turd-250's Avatar
this is so much fun!
Turd-250 is offline
post #8 of 9 (permalink) Old 10-30-2019, 02:53 PM
Sorry to have left off the cranking details.
Mark
bismic1 is offline
post #9 of 9 (permalink) Old 10-30-2019, 03:35 PM Thread Starter
Turd-250's Avatar
i found a sweet DTR video!
bismic1 likes this.
Turd-250 is offline
