05 f350 truck will die while coming to a stop then have difficulty starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By River Red Neck
  • 1 Post By bismic1
post #1 of 9 (permalink) Old 10-22-2019, 04:42 PM Thread Starter
Here's my story, I had injector 6 go down, had to drive it for a week till I could get another injector, changed it out, truck fired up and ran awesome again......for a couple days, then I was driving into a parking lot and the truck died, i cranked it over and it took a few tries to get it to fire, when it did it ran great. It did the same thing a couple of more times over the next couple days, each time was the same, I was coming to a stop and it would die. This morning I started my truck, it fired up good, after about ten minutes of warm up, it died and I couldn't get it to start up again for about 15 mins, i had it plugged in because it is getting below 0c at night, the block heater and the glow plugs work just fine. I'm baffled as this has never happened until recently. Any help or in-site would be much appreciated
River Red Neck is offline
post #2 of 9 (permalink) Old 10-22-2019, 05:18 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: 05 f350 truck will die while coming to a stop then have difficulty starting
welcome to the forum!
The only thing touched was the #6 injector right? might be the oring leaking off oil. Sis you install it or did a shop?
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 9 (permalink) Old 10-22-2019, 05:19 PM
Turd-250's Avatar
to confirm this, you can watch the ICP pressure with a monitor or scanner. good thing to have on hand with the wonderful 6.0 anyways lol
Turd-250 is offline
post #4 of 9 (permalink) Old 10-22-2019, 06:36 PM Thread Starter
Thanks for the help, I installed the injector myself, I have done lots of injectors in my truck as well as friends trucks as well, would ICP cause these issues? Would me having to run the truck with the fouled injector cause my ICP or IPR to fail?
Turd-250 likes this.
post #5 of 9 (permalink) Old 10-22-2019, 06:58 PM
"resident smarty pants"
Fouled injectors aren't going to cause a no-start when hot.
Do you still have the original dummy plug? How about the original discharge fitting (STC) on the HPOP?
Mark
bismic1 is offline
post #6 of 9 (permalink) Old 10-22-2019, 07:34 PM Thread Starter
Yes and yes
post #7 of 9 (permalink) Old 10-22-2019, 07:53 PM
Watch ICP pressure (psi), ICP volts, and IPR % duty cycle. Be prepared to do an air test of the high pressure oil system.
Leaking (original) dummy plugs are the most common leak point in an 05+ engine. The original standpipes have been upgraded also. You will probably need to install both of these upgrades in both oil rails.
The STC fitting fails frequently also. You have to access the HPOP for this install. It is a bit more involved, but the thing with it is that sometimes it fails catastrophically and if it does, it can crack the rear cover. The upgraded one-piece fitting resolves this issue.
Mark
bismic1 is offline
post #8 of 9 (permalink) Old 10-22-2019, 08:21 PM Thread Starter
Thanks for the great info, I will do the dummy plug and stand pipe upgrade and STC fitting, I appreciate your help
post #9 of 9 (permalink) Old 10-23-2019, 12:04 AM
If work has recently been done on the injectors (or the oil rail removed), you can have a leak on them as well. That is why an air test is important.
Mark
bismic1 is offline
