Runs great then dyes after 15 to 20 min. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-21-2019, 09:59 PM Thread Starter
Hello all im a new member hope someone can help.😀
I have a 2005 6.0 was driveing down the road it Acted like it was running out of fuel then dyed.it would not restart had to get it towed home. I replaced the 2 fuel filters and replaced the cam sensor and the crank sensor then the ficum.the mechanic said he was 75% the ficum it was not then the other parts did not help. I have torque pro I will post screen shot.now it sits in my drive way can't drive it because I don't know what's wrong with it allready spent close to 700$ .I have video of it sputtering can't upload it.
File Type: jpg Screenshot_20190920-130102_Torque_1569098580139.jpg (10.4 KB, 8 views)
File Type: jpg Screenshot_20190920-130431_Torque_1569098613663.jpg (10.2 KB, 8 views)
File Type: jpg Screenshot_20190920-124656_Torque_1569098651496.jpg (10.3 KB, 5 views)
Jason Patterson is offline
post #2 of 6 (permalink) Old 09-22-2019, 03:09 AM
"resident smarty pants"
Re: Runs great then dyes after 15 to 20 min.
IMO you need a fuel pressure gauge.
You could also do a fuel bubble test. there are youtube videos on it. This test checks for injectors leaking combustion gas backward into the fuel system which prevents proper fuel flow.
Mark
bismic1 is offline
post #3 of 6 (permalink) Old 09-27-2019, 12:08 PM
It almost sounds like an internal high pressure oil pump leak. If the STC fitting on the HPOP is allowing oil pressure leak it will not get enough pressure to the branche rails causing a shut down or fails to start after running for a while. It happens after the engine warms up. This is a common issue with this engine. It drove me bonkers until I figured it out.
VaBeach DSLFan is offline
post #4 of 6 (permalink) Old 09-27-2019, 12:17 PM
Master BS'er
jamiesaun's Avatar
Figure out if there's a pulse width or not when it dies. That'll be a pivotal step
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 6 (permalink) Old 09-27-2019, 08:16 PM
His ICP and IPR values look fine. This indicates his issue is somewhere else.
He has some good advice above, but this sure looks like another thread w/ a single post and no-answer to questions.
Mark
bismic1 is offline
post #6 of 6 (permalink) Old 09-28-2019, 12:38 AM
matthewd11's Avatar
There seem to be a lot of those lately. Forum jumpers
matthewd11 is online now
