Hi, I've replaced all three ABS sensors and my speedo registers the correct mph and doesn't bounce etc. The ABS light is on solidly. Every now and then (maybe once a month), the ABS will kick in, rattle the brake pedal, and the light will go off. Then later on it will come back on. Fuse 11 is fine too.
I have a vanilla OBD scanner which didn't seem to give any codes. I want to verify the circuits from the sensors back up to the ABS unit in front of the fuse box and need help with which pins on that gigantic connector are for the sensors - could someone share which ones to check?
Are there any other components of the ABS apart from the module itself in the engine bay, and the three sensors? Anything else I can check?
Thanks!
Thanks!
