Air in oil filter housing - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 22 (permalink) Old 09-04-2019, 10:07 PM Thread Starter
longjonsilver's Avatar
Iím fooling with a 2004 6.0 and itís a no start . There is zero oil pressure on the dash gauge . I removed the oil filter cap and cranked the engine and I noticed small air bubbles and then some large air bubbles followed by some oil . Iím putting a new starter in since this one doesnít turn the engine fast enough and gets very hot very quickly. Any thoughts ?
Broken pick up tube ? Bad o ring ?
longjonsilver is offline
post #2 of 22 (permalink) Old 09-04-2019, 10:46 PM
matthewd11's Avatar
Before you do anything else I would remove the oil pump regulator and see if there is debris in it. If there is I would remove the oil pump and check for any imprints of needle bearings and inspect the overall condition of the pump gears. It’s the Allen bolt on the passenger side of the pump housing by the balancer
longjonsilver likes this.
matthewd11 is offline
post #3 of 22 (permalink) Old 09-04-2019, 10:46 PM
PSN intsigator
heavydoc's Avatar
Re: Air in oil filter housing
Im going with low on oil, broken pick up tube or bad low pressure oil pump.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #4 of 22 (permalink) Old 09-05-2019, 01:55 AM Thread Starter
Iíve seen the needle bearing failure first hand so Iím not ruling that out . The truck is being towed to the shop tomorrow or Friday. Iím going to look at it ASAP . I just wanted a head start so to speak on diag . Iím fooling with a B model 3406 thatís leaking fuel and Sterling road tractor that has some AC problem . Thanks for the input and Iíll keep yíall posted .
jamiesaun likes this.
post #5 of 22 (permalink) Old 09-06-2019, 03:40 PM
matthewd11's Avatar
Any updates?
post #6 of 22 (permalink) Old 09-10-2019, 09:30 PM Thread Starter
Originally Posted by matthewd11 View Post
Any updates?
Ok I finally got to the shop to look at this thing . Found it 8 quarts low on oil so I added oil , replaced the starter as well . I then removed the oil pressure relief valve and it was clean as a whistle. The engine turns over much faster but the batteryís need charged . I burned up my alternator in my service truck . Still have air in the system when cranking while the oil filter cap is off . Another observation is that the oil filter is never soaked in oil regardless of how long you crank it . Is there a possibility of a messed up drain valve in the bottom of the oil filter housing . I can crank the engine long enough that the oil will overflow out of the housing with cap and filter removed .
post #7 of 22 (permalink) Old 09-10-2019, 09:34 PM Thread Starter
Bet this has something to do with it ...
post #8 of 22 (permalink) Old 09-10-2019, 10:36 PM
"resident smarty pants"
Looks to me like you have a tall oil filter cap. If you have an OEM oil filter and a tall cap, you NEVER will close the filter housing drain valve.
Mark
bismic1 is offline
post #9 of 22 (permalink) Old 09-10-2019, 10:44 PM Thread Starter
Thatís what I was thinking . Iíll go pick up a different oil filter tomorrow and retest .
post #10 of 22 (permalink) Old 09-10-2019, 10:54 PM
If I were you I would buy an OEM oil filter cap and an OEM oil filter.
Your cap clearly says to NOT re-use and I bet it was re-used.
Mark
bismic1 is offline
