WTF?! Loss of electrical - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-22-2019, 03:39 PM Thread Starter
Weatherlite's Avatar
Garage
I'm hoping the wtf gets some attention. I had something happen last night that really concerns me, but I can't find anything about it....I lost my electrical while driving. But, I didn't.
Vehicle is the Ex in my sig. Nothing unusual about how things are set up. I do have a 250 amp alternator and two brand new (bought em a month ago, manufactured in April for both) AGM batteries. I have all 2/0 cable, properly terminated, sealed, etc. Electrical setup hasn't given me a lick of trouble in years.
As for what happened, I was driving home from the store, in town, at about 25MPH. Suddenly, with no warning, no prelude, nada, everything in my truck except for the lights and the engine turned off. Everything then went through a test cycle like it would when you first turn on the key and then remained on for the rest of the drive.
First thought is it has something to do with the key, but the key was never touched, and since the FICM and fuel pumps stayed on as well, it doesn't feel right. So, I'm wondering if there is a connection which houses most, but not all, of the items controlled by the key.....something that would let what I described happen. Any thoughts?
Sent from my Moto Z (2) using Tapatalk
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #2 of 9 (permalink) Old 06-22-2019, 03:42 PM
"resident smarty pants"
Re: WTF?! Loss of electrical
Possible it is the battery saver circuit in the Instrument Cluster
Mark
bismic1 is offline
post #3 of 9 (permalink) Old 06-22-2019, 04:26 PM
matthewd11's Avatar
battery saver relay in the cluster is failing.
matthewd11 is offline
post #4 of 9 (permalink) Old 06-22-2019, 04:43 PM Thread Starter
Garage
Well that's a new one on me! What's a battery saver relay, and can it be replaced? Gonna start googling now.
2004 Excursion 6.0
post #5 of 9 (permalink) Old 06-22-2019, 05:42 PM Thread Starter
Garage
Did the research already. Here's the million dollar question: can this HEC module be bought by the average Joe? I have good soldering skills and have confidence I could do it, but I can't actually find it for sale anywhere, nor can I find a pic or video specifying which component it is on the back of the cluster.
2004 Excursion 6.0
post #6 of 9 (permalink) Old 06-22-2019, 06:22 PM
matthewd11's Avatar
It’s a PCB relay soldered to the board. Send the cluster to circuit board medics and they can repair it
post #7 of 9 (permalink) Old 06-22-2019, 07:27 PM
My understanding is that the battery saver relay works with the accessory delay relay which is in the fuse/relay box. Your problem may be with the accessory delay relay rather than the battery saver relay, but that is very uncommon.
https://ww2.justanswer.com/uploads/s...5_021056_0.jpg
Check this out (or just send it in!):
https://www.justanswer.com/ford/4tok...t-working.html
Mark
bismic1 is offline
post #8 of 9 (permalink) Old 06-22-2019, 08:40 PM
matthewd11's Avatar
Bismic you are correct. The battery saver relay controls the accessory delay relay. Like you said the ADR isn’t a common failure
post #9 of 9 (permalink) Old 06-24-2019, 02:13 PM Thread Starter
Garage
Some great info there! I also ran across quite a few stories of bad solder joints, so I decided to go ahead and reflow the solder on anything I could on the board. Found several junctions which looked questionable. Guess we'll see how this works. If it happens again, I'll probably just send it in. Just wish I could find out what to replace so I could do it myself. Hate paying someone else to do something I am capable of performing.
2004 Excursion 6.0
