‘05 6.0 No start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 06-15-2019, 09:48 PM Thread Starter
Eric
jkeen579's Avatar
‘05 6.0 No start
Here are my readings on my Scan Gauge ll
RPM = 193
ICP = 234
IPR = 84.7
FICM = 48.5v
FICM sync = 1
I am at a total loss.
2005 F250 6.0
Short story. #2 injector replaced along with dummy plug and stand pipe on the left bank. Drove for 2 months and started missing and kind of sluggish. Did the air test through the IPR port and both the stand pipe and dummy plug o-ring were completely blown. Replaced with the other two I had left over and no air leak now but still not enough oil pressure. I’m thinking HPOP. What about you all?
jkeen579 is offline
post #2 of 27 (permalink) Old 06-15-2019, 11:58 PM
"resident smarty pants"
Re: ‘05 6.0 No start
I doubt it is the HPOP. Could be the STC fitting on the HPOP discharge though. Could also be an IPR issue.
Mark
bismic1 is offline
post #3 of 27 (permalink) Old 06-16-2019, 12:23 AM Thread Starter
Eric
jkeen579's Avatar
STC fitting already upgraded. New IPR just installed.
jkeen579 is offline
post #4 of 27 (permalink) Old 06-16-2019, 12:28 AM
Not sure why you have two threads going .........
https://www.powerstrokenation.com/fo...n-t-start.html
What are the ICP volts when cranking?
Mark
bismic1 is offline
post #5 of 27 (permalink) Old 06-16-2019, 01:03 AM Thread Starter
Eric
jkeen579's Avatar
I didn’t know if I should post on the other one since it was a month old.
jkeen579 is offline
post #6 of 27 (permalink) Old 06-17-2019, 04:48 PM Thread Starter
Eric
jkeen579's Avatar
Hey bismic1, I was just reading your post on pressure testing the high pressure oil system. I still have my adapter in the IPR port. If I put pressure to the system and hear gurgling in the oil filter housing would you be pretty confident saying I got a bad HPOP. I had not heard this before and was reading your comments on someone else’s post. What do you think.
jkeen579 is offline
post #7 of 27 (permalink) Old 06-17-2019, 05:35 PM
That is a sure sign of a bad HPOP. You can hear it from the turbo drain tune also with a bad HPOP.
Mark
bismic1 is offline
post #8 of 27 (permalink) Old 06-17-2019, 05:40 PM Thread Starter
Eric
jkeen579's Avatar
Thank you. I’ll be trying that this evening when I get home.
jkeen579 is offline
post #9 of 27 (permalink) Old 06-17-2019, 05:46 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
that's like only the 3rd bad 'late' 6.0 HPOP that i've even read about on here lol, and that's in about 6 years of snooping the 6.0 section
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #10 of 27 (permalink) Old 06-17-2019, 07:45 PM Thread Starter
Eric
jkeen579's Avatar
No gurgling.
jkeen579 is offline
