Rough idle intermittently - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-09-2019, 11:32 PM Thread Starter
I have an 06 f350 6.0 with 164000 miles I've had the truck for 2 months and all the sudden every once in a while it will develop a rough idle. Once you get into the throttle it goes away. I'm wondering if this could be a fuel filter problem. It didnt do this till I ran a bottle of diesel clean through it. Please help
Davidwebb9913 is offline
post #2 of 2 (permalink) Old 06-10-2019, 10:11 AM
"resident smarty pants"
Re: Rough idle intermittently
Download ForScan Lite to a smart phone. Get the appropriate ELM32 OBDII adapter (blue tooth or WiFi) and pull codes.
In the meantime, you might try starting and idling w/ the ICP sensor disconnected (cheap and easy thing to try).
Mark
bismic1 is offline
