6.0 questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 05-20-2019, 04:33 PM Thread Starter
6.0 questions
Got a 06 f350 lifted 8 inches with 37s have it geared to a 4:56 using a sct livewire what should the coolant and oil deltas be at 60 mph
Sid Revels is offline
post #2 of 13 (permalink) Old 05-20-2019, 05:50 PM
matthewd11's Avatar
15 degrees or less. Personally like to see single digits.
matthewd11 is offline
post #3 of 13 (permalink) Old 05-20-2019, 06:19 PM Thread Starter
Ok imma try the flush if not I have a cooler. Thanks
post #4 of 13 (permalink) Old 05-20-2019, 09:17 PM
Do you have a stock oil cooler?
Drock707 is offline
post #5 of 13 (permalink) Old 05-29-2019, 05:11 PM
IQRaceworks's Avatar
Re: 6.0 questions
I see around 5-6 deg delta's when on the highway at 60mph....what's with a new oil cooler. When towing, it will get up to 10-12 depending on how much of a load you are putting on the truck.
When I bought the truck a couple of years ago....I was hitting 15 deg on the highway with no load, so I rebuilt the oil cooler.....problem solved.
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
IQRaceworks is offline
post #6 of 13 (permalink) Old 05-29-2019, 05:12 PM
Re: 6.0 questions
Make sure it's an OEM Ford oil cooler....I've heard of lots of guys having issues with the cheap aftermarket coolers, especially the seals they come with.
post #7 of 13 (permalink) Old 06-12-2019, 05:25 AM
Xcursion813's Avatar
I’ve heard that when you flush your coolant and replace a bad oil cooler it is best to add a second filter and change the filter on it every 1500 miles 3/4 times after replacing your oil filter. I was told that if you don’t there could still be contaminated in the system that can cause your oil cooler to start to fail again within a short time. Opinions???
Xcursion813 is offline
post #8 of 13 (permalink) Old 06-12-2019, 12:31 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: 6.0 questions
secondary/bypass oil filter or coolant filter?
with a coolant filter, i'm in the camp where the sooner you can start filtering the coolant, the better. That way when you replace oil cooler, you'll have less stuff to break loose and clog your new one.
for the oil filter...I don't think its common for the oil veins to clog, but since the motor overall is so sensitive to oil, having better oil filtration is pretty darn nice. it could save you on injectors in the long run at the least.
usually either @bismic1 or @Weatherlite or somebody comes along with better info when i answer questions like this lol, I can't wait to see what the have to say!
edit: or @matthewd11 up there, or @jamiesaun lol
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
my farts are so bad, they have been banned in 37 countries!
Turd-250 is offline
post #9 of 13 (permalink) Old 06-12-2019, 01:32 PM
"resident smarty pants"
Re: 6.0 questions
Spot on Rob. Oil coolers have plugged on the oil side, but it is rare and due to neglect.
Mark
bismic1 is offline
post #10 of 13 (permalink) Old 06-12-2019, 03:38 PM
Weatherlite's Avatar
Garage
Re: 6.0 questions
Agreed. No need for an extra oil filter unless you're looking for ultra filtration like I am. Only severe neglect will clog that part. The bypass, or even full flow, coolant filter however, as well all know, is a necessity. I know I changed mine every 500 miles for twice, and then again after 1000 more, and it was gradually less and less filled with gunk. I now change it with the oil and I rarely see anything in it anymore, save for the odd piece of casting sand which is still somehow floating around in there. lol
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
Similar Threads
e4od questions / build questions. geared_low550 Transmission Related 10 12-13-2012 02:43 PM
Questions.....Questions silverbullet4x4 General Questions & Discussion 43 04-05-2011 05:51 PM
questions, questions, questions? southerncomfort 1994-1997 OBS Power Stroke - Aftermarket & Performance 15 01-29-2011 04:18 PM
Engine Rebuild Questions Preliminary Questions JohnT 7.3L Power Stroke Technical Info 10 08-20-2008 05:24 PM
