06 6.0 no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-19-2019, 05:18 PM Thread Starter
06 6.0 no start
Had a leak in tge hp oil system wnt in replaced dummy plgs and standpipes to updated changed ipr valve, stc fitting to updated, resealed all injectors and cups.
Afterwards i pressure tested with air and its completely sealed. I let it sit pressurized for 5 hrs no change still no start. Ipr and icp is at 84.7% and 324 psi.
Could this be a bad hpop or some electrical issue? I checked fuses seem good. At a loss
Tonyl is offline
post #2 of 6 (permalink) Old 05-19-2019, 05:37 PM
"resident smarty pants"
Re: 06 6.0 no start
Sometimes you have to crank quite a bit to get all the air out. Cranking w/ the FICM relay removed is best because excess cranking and low battery voltage can damage the FICM.
Mark
bismic1 is offline
post #3 of 6 (permalink) Old 05-19-2019, 06:59 PM Thread Starter
I am gonna try soon as i am on a charge right now with these batterys
Tonyl is offline
post #4 of 6 (permalink) Old 05-19-2019, 08:33 PM Thread Starter
Got it started. However after running for about 20 min got a 0261 code injector 1
And shortly after got a 2290 code any ideas?
Tonyl is offline
post #5 of 6 (permalink) Old 05-19-2019, 11:18 PM
Re: 06 6.0 no start
P0261 is an electrical code, so verify the injector connector is properly connected.
Sometimes you need some "spirited" accelerations to get the air out. Try 5-10 good accelerations (doesn't have to be "foot-to-the-floor") after checking the injector connector.
Mark
bismic1 is offline
post #6 of 6 (permalink) Old 05-20-2019, 05:02 PM
CAT lover
Robertl211's Avatar
Re: 06 6.0 no start
I did a whole bunch of work to my buddies truck including injectors, LPOP, front cover, STC fitting, stand pipes and dummies, oil cooler, turbo, egr delete, and some other things i cant think of right now. Took about 60 seconds cranking to get it to fire up and then had the same issue, one injector code and rough running with smoke. Mine was a contribution and cyl misfire codes. either way, it took an honest 30 min of driving it like I stole it to work the air out of the injector but when it finally cleared up its like a brand new truck now.
I was never a believer of the "it takes up to 30 min to get the air out of the injection system" and the "drive it like you stole it to get the air out" but I am now.
Plus driving it like you stole it keeps the veins clean on the VGT
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
Similar Threads
Crank hard start /no start /long crank start-not covered by sticky Volkskid 7.3L Power Stroke Technical Info 5 02-07-2018 03:39 AM
Odd start, stall, no start, start situation Weatherlite 6.0L Power Stroke Technical Info 6 08-27-2016 12:46 PM
No start tach no move and no wait to start light kram 7.3L Power Stroke Technical Info 5 12-26-2013 07:42 PM
'03 no codes, no oil press. no start, no idea jakejamie 6.0L Power Stroke Technical Info 8 01-05-2013 05:23 AM
no start started fine then died and no start or wait to start jrf350 1994-1997 Power Stroke Technical Info 10 11-05-2011 01:22 AM
