05 no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-12-2019, 05:20 PM Thread Starter
05 no start
I am new to powerstrokes. I bought an 05 that had been bulletproofed about 5 years ago and shortly after he was driving it and it died wouldn’t start back and he parked it. Ficm showed 48.5volts icp was only 250psi ipr was 84.7%
I pulled ipr and it had a bad oring so i cleaned ipr and I replaced with new ones as well as a new screen. Put back together and still only get 250psi while cranking. I have 12 volts on red wire goin to ipr and I have fitting for air test ordered. Is there any way to test ipr before I buy a new one? Or am I chaseing the wrong issue? Thanks for all the help and sorry for long post.
Flatbeddiesel is offline
post #2 of 2 (permalink) Old 05-13-2019, 02:21 AM
Re: 05 no start
I would do the IPR test, if youíve got it that far apart. Make sure you donít have any leaks with injectors or the hpop.
2003 Excursion EB 6.0 PSD: BPD Oil Cooler, Water Pump, 7.3 fan adapter: Adrenaline Stock HPOP: APR Head Studs (One at a time): KC Turbo Billet Compressor: EGR Delete: Sinister Coolant Filter & Regulated Fuel Return: '08+ Oil Pan/Filter: SCT LiveWire TS+
Tte531 is offline
Similar Threads
Odd start, stall, no start, start situation Weatherlite 6.0L Power Stroke Technical Info 6 08-27-2016 12:46 PM
No start tach no move and no wait to start light kram 7.3L Power Stroke Technical Info 5 12-26-2013 07:42 PM
'03 no codes, no oil press. no start, no idea jakejamie 6.0L Power Stroke Technical Info 8 01-05-2013 05:23 AM
no start started fine then died and no start or wait to start jrf350 1994-1997 Power Stroke Technical Info 10 11-05-2011 01:22 AM
05 F250 no start, no crank bluedge8 6.0L Power Stroke Technical Info 12 04-19-2011 02:19 AM
