Is upgrading the 5R110 solenoids worth it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-06-2019, 09:33 PM Thread Starter
2006 CCLB 6.0 5R110 211k miles
I recently tuned my FICM and a note in the package said that with the higher levels of ficm tuning, it's recommended that you upgrade your 3-5 shift solenoids, the weak part of the 5R110 transmission.
Is it worth it? I only tow a car trailer with gear in the bed at most. Total weight of truck, trailer, car on the trailer, and gear in the bed is probably around 16k-18k pounds. So nothing too crazy. I know some people out there tow more than that in the 5th wheel trailer alone.
And if I do decide to upgrade the solenoid, which ones actually need replacing? The 3rd gear solenoid? I can't seem to find a straight answer, I've found a few write ups but they don't specify which solenoids control the 3-5 shift
https://performancetruckproducts.com...oke-6-0l-6-4l/
My transmission doesn't have the 3-5 flare yet but I'm looking to replace the solenoid as a precautionary measure.
koukimonster is offline
post #2 of 7 (permalink) Old 05-06-2019, 10:56 PM
matthewd11's Avatar
Save your money it’s a useless upgrade IMO and I build these transmissions . I’ve never installed one. Use proper transmission tuning instead. My personal one was done almost 6 years ago and was tuned at the same and haven’t had a problem nor with any of the other I have built
WIth that mileage has however i wouldn’t be surprised if you develop issues with the added power if the trans has been 100% untouched
matthewd11 is offline
post #3 of 7 (permalink) Old 05-09-2019, 07:14 AM Thread Starter
Re: Is upgrading the 5R110 solenoids worth it?
Originally Posted by matthewd11 View Post
Save your money itís a useless upgrade IMO and I build these transmissions . Iíve never installed one. Use proper transmission tuning instead. My personal one was done almost 6 years ago and was tuned at the same and havenít had a problem nor with any of the other I have built
WIth that mileage has however i wouldnít be surprised if you develop issues with the added power if the trans has been 100% untouched
Got it, I went with the Atlas 40 tune, so I'm hoping it's not going to blow my trans. Mainly wanted better throttle response off the line and a bump in fuel economy.
Any thoughts on the dummy plug replacements? Upgrading the stock plastic one(s) to metal?
I thought these transmissions were pretty tough as far as longevity was concerned? I recently drained it, changed the filter and pan to a 6.4 set up and everything looked pretty good, normal amount of metal on the magnet and the fluid was dark but still red.
post #4 of 7 (permalink) Old 05-09-2019, 11:57 AM
"resident smarty pants"
Nothing needs to be done to the transmission plugs either
Mark
bismic1 is offline
post #5 of 7 (permalink) Old 05-09-2019, 12:24 PM
matthewd11's Avatar
They are stout transmissions. With the age and mileage of the transmission piston seal integrity becomes an issue as rubber deteriorates as it ages. Also the steel plates tend to start shedding metal around that mileage . The first sign of that will be erratic operation (small metal particles that hang up the shift solenoids. My trans lasted 6k miles after I added tunes (steel plates failed at 173k miles). I built with good parts and haven’t had a problem for the last 6 years and same goes for others I have done.
Your 06 doesn’t have pressure switches that’s need plugging so no need for that either.
post #6 of 7 (permalink) Old 05-09-2019, 12:54 PM
fyi - Here are the plugs he asked about
Transmission dummy plug
Some say they fail. IMO it is a non issue.
Mark
bismic1 is offline
post #7 of 7 (permalink) Old 05-09-2019, 02:23 PM
matthewd11's Avatar
Ive only seen those on the very eary models the late model ones don’t have them. Sometimes there is a plug in only one port but I have never touched one. Another useless thing to buy IMO
OP save your money for a nice overhaul kit. The best thing to make these transmissions live is proper tuning to go with the added power.
Similar Threads
losing solenoids lpx Transmission Related 11 02-01-2013 11:17 PM
anyone have a schematic of solenoids in 5r110 chappy Transmission Related 0 01-08-2012 03:54 PM
