Time to address the FICM? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-04-2019, 12:22 AM Thread Starter
First vid is from after work yesterday and 2nd is from before work this morning. I haven't had any of the starting issues (started up a couple times this past winter in -20 degree weather) or other signs of a bad FICM, but I've been more diligent in monitoring lately and noticed the low voltage. Seems like after driving for a couple minutes and warming up a bit it settles in and stays between 47-48 volts. I have a leece neville 230 amp alternator and the batteries are a few years old and get put on a tender on a regular basis (just for good maintenance), so I think I should be good there. Anything else I should check before looking into replacing the FICM?
house of wax is offline
post #2 of 2 (permalink) Old 05-04-2019, 01:20 AM
"resident smarty pants"
Re: Time to address the FICM?
I would send it to FICMrepair.com for a rebuild, instead of replacing it.
Mark
bismic1 is offline
Similar Threads
Immigration - The next problem to address AK Gandy Politics and Religion 241 03-26-2010 03:56 AM
Any issues I should address with the engine out? gots_a_sol 1994-1997 Power Stroke Technical Info 16 09-22-2009 12:56 PM
New Address and Phone Number Strictly Diesel Power Stroke Nation Vendors 7 05-14-2009 02:28 AM
TS Sled Pull address? imelmo National Events 9 05-05-2009 11:03 PM
Is there such thing as a digital address book? PTSUPERD General Questions & Discussion 19 12-24-2008 08:35 PM
