05 stroke Battery drain, hard starting. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 05-03-2019, 12:32 AM Thread Starter
ANIMOSITY's Avatar
Alt wasn't charging so I replaced it and that helped, but now if the truck sits for a bit it will drag when starting. So I checked for a draw and sure enough there is one, light is pretty bright. Traced it down to fuse 2 and 34, the cluster and BOO. So I torn into the dash and when I disconnect the blue plug in the cluster the draw goes away. Any ideas anyone? Want planning on selling anytime soon, but I am getting tired of fixing stuff, which seems like it's all the time. Just need the truck to last till my next deployment, then I'm looking at buying something newer. Thanks
For those who fought for it, Freedom has a taste the protected will never know!
ANIMOSITY is offline
Similar Threads
2 problems: battery drain,hard start jjlw 6.0L Power Stroke Technical Info 6 12-28-2015 09:35 PM
strange battery drain solareclpse2000 7.3L Power Stroke Technical Info 24 05-09-2013 02:07 AM
BATTERY DRAIN!!!! jlwalker9 7.3L Power Stroke Technical Info 9 07-27-2009 04:28 AM
Bad battery drain. SootRoller 7.3L Power Stroke Technical Info 4 02-07-2009 02:26 PM
Battery drain DonM 7.3L Power Stroke Technical Info 2 09-05-2008 02:12 AM
