‘06 6.0 No Crank After Shorting Battery With Key On - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-02-2019, 09:11 PM Thread Starter
frankieboytwo@yahoo.com's Avatar
It started initially with tow/haul flashing and tranny clunking from Park to Reverse to Drive and back to Park. Turned truck off. It would not crank again. Checked codes and got P0113, P0705 and P0706. Checked all relevant fuses I thought may have blown. I’ve replaced the Trans Range Sensor. After that I checked and the reverse lights are not coming on which I’ve read is a symptom of a bad TRS, I just installed a new one. I haven’t put fluid back in yet in case I had to open it back up. Could that prevent cranking? Wouldn’t think so, but idk. Any other ideas?
post #2 of 5 (permalink) Old 05-03-2019, 02:04 AM
Master BS'er
jamiesaun's Avatar
Re: ‘06 6.0 No Crank After Shorting Battery With Key On
Give the code definitions because I don't feel like looking them up..
What do you mean shorted the battery
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 5 (permalink) Old 05-07-2019, 06:11 PM Thread Starter
Thanks for responding. Codes are 0113 air intake temp high input, 0706 Transmission Range Sensor Circuit Range/Performance, 0707 Transmission Range Sensor Circuit Low Input. Upon further review, I think those are just symptoms of a different problem. Found the fan clutch harness had come loose and was cut in half. As for shorting the battery, key was on, I was reinstalling battery and in the process a wrench contacted the disconnected positive cable and sparked. Since key was on, I thought maybe TRS, a fuse or relay had fried.
post #4 of 5 (permalink) Old 05-08-2019, 12:42 AM
Master BS'er
jamiesaun's Avatar
No, you won't fry anything by doing that.
Brother James
post #5 of 5 (permalink) Old 05-08-2019, 10:35 AM
"resident smarty pants"
Be sure to check fuse F2.22 (20A Engine Controls fuse #22) under the dash
Mark
bismic1 is offline
Similar Threads
First Ford Diesel. ‘07 F350 FX-4. TonyHo New To The Nation 0 07-08-2018 07:28 PM
‘89 350 7.3 auto dually 2x4 to 4x4 Jean-Michel Varlet 6.9 - 7.3L IDI Diesels 83-93 Model Years 0 04-07-2018 07:47 PM
2000 7.3 won't start after shorting battery cable netcott 7.3L Power Stroke Technical Info 4 03-04-2014 01:43 AM
CAT Injector 127-8216 chinahanjipump Car & Truck Audio 0 08-01-2011 06:43 AM
HPOP Drains down instantly after refill & crank PLUS (no start with key) JACKASS 7.3L Power Stroke Technical Info 12 05-04-2010 02:34 PM
