White smoke on start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-02-2019, 01:55 AM Thread Starter
Recently my truck has been puffing white smoke for the first minute of driving it. I thought it was just condesation burning off but it puffs white smoke after i go into the store or at the gas station. If it sits for 10-15 minutes it will puff white smoke when i start the truck and when it idles there will be a slight haze of white smoke, when i pull outt on the road it will just blow white smoke like a train, eventually it will stop but it kind of has me worried... I cant check the egr valve yet cause i dont have the replacement gasket when i remove the valve. I unplugged the egr valve to see if it makes a difference in the smoke but it doesnt. Im new to diesels so i dont know whole lot about them yet.
Thanks for the replies!!
6.0tex is offline
post #2 of 3 (permalink) Old 05-02-2019, 11:09 AM
"resident smarty pants"
Re: White smoke on start
Very well might be an injector or several injectors that are dumping fuel. Not something to let go for long.
Get something to read codes with. IMO downloading ForScan to a smartphone is a great option. You will need to buy an ELM327 OBDII adapter with that. Total cost is around $40.
Mark
bismic1 is offline
post #3 of 3 (permalink) Old 05-16-2019, 08:41 AM
Did you get anything to read engine parameters with? I see you have other posts, but no response to this one.
Mark
bismic1 is offline
Similar Threads
6.0 black smoke and white smoke. Fuel injector code? MellyMel2186 6.0L Power Stroke Technical Info 4 06-25-2016 05:03 PM
White Smoke and Black Smoke Please Help - Can't afford a new vehicle 777funk 1994-1997 Power Stroke Technical Info 12 07-04-2013 03:09 AM
white smoke no power turbo spools then black smoke and power jminardi 6.0L Power Stroke Technical Info 1 11-18-2010 12:01 AM
white smoke, then blue smoke then black justintimemoto 6.0L Power Stroke Technical Info 6 08-12-2010 02:01 AM
White smoke VS Black smoke (PICS) Redfish General Questions & Discussion 11 07-13-2008 03:30 AM
