New to powerstrokes have an idle question - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Turd-250
post #1 of 5 (permalink) Old 04-25-2019, 03:57 PM Thread Starter
Hello I own a 2004 f250 and I have a random question. Background on the truck. Has been bullet proofed still has egr(brand new) bully dog programmer brp 4 inch turbo back. New FICM. When the truck is warm and is idling it will sound like it is trying to build boost maybe a 1 psi (according to bullydog controler) for 15 seconds then stops and goes really deep sounding for 30 seconds then stops and idles normally for a min then restarts again. The only code I have is map to barometer code and fan clutch control issue. The weird thing is the fan clutch is new. Other then that the the truck runs great no oil consumption 14 mgp on the highway. Just towed a car back and it ran great. Anyone know if that is normal?
Mrbeef612 is offline
post #2 of 5 (permalink) Old 04-26-2019, 05:11 AM Thread Starter
Hello any one around here any more?
post #3 of 5 (permalink) Old 04-26-2019, 12:39 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: New to powerstrokes have an idle question
howdy howdy howdy!
might that just be the the computer sweeping the vanes of the turbo?
Weatherlite likes this.
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #4 of 5 (permalink) Old 04-29-2019, 12:52 PM
Weatherlite's Avatar
Garage
Originally Posted by Turd-250 View Post
howdy howdy howdy!
I'm going with this as well. Sounds like what some of the stock tunes do....they swept the turbo vanes back and forth at idle in an attempt to keep soot from building up and causing the vanes to stick. And yes, it will change the sound of the exhaust that dramatically. Perfectly normal.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #5 of 5 (permalink) Old 04-29-2019, 01:47 PM
Master BS'er
jamiesaun's Avatar
For sure. In fact, that was a software update put out by Ford some time after the 6.0 came out. It was meant as a fix for the coked turbos. If your truck doesn't do this, you should get it updated.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
Similar Threads
New Here and New To Powerstrokes clausont New To The Nation 6 01-20-2019 01:28 AM
New here and new to the Powerstrokes mrhockey New To The Nation 0 10-12-2013 01:18 AM
Anybody have a Color sheet, and production number for 1994.5-1997 Powerstrokes? Seven Three 1994-1997 Power Stroke Technical Info 1 06-12-2012 07:03 PM
New from Spokane, WA but not new to Powerstrokes Specializeddieselnw New To The Nation 10 11-25-2009 01:00 PM
Performance ideas? Im new to powerstrokes StrokerTurbo7.3 1994-1997 OBS Power Stroke - Aftermarket & Performance 12 08-28-2007 03:40 AM
