Leak Issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-19-2019, 06:37 PM Thread Starter
Leak Issue
I’m new to the 6.0 Powerstroke. I’ve had a few 6.4L so I apologize in advance is this has been asked a bunch. I recently purchased the truck and noticed there was an oil leak. I took it to my mechanic and found out the oil cooler was leaking. The oil cooler was replaced and oil chance completed. Now I’m finding a leak on what appears to be the front of the transmission but the oil is black. Hopefully you can see the pictures and let me know what might be the source of the leak.
File Type: jpeg 28700C35-27CD-4A49-8C70-E5396380D25F_1555699064170.jpeg (967.2 KB, 26 views)
Hooton43 is offline
post #2 of 2 (permalink) Old 04-22-2019, 02:26 PM
Weatherlite's Avatar
Garage
Re: Leak Issue
Just about any leak on the top of the engine will wind up running down the valley to the back of the engine and then it will run down the front of the tranny, giving you what we see in the pic. It's possible the leak is gone and that is just residual oil making its way back, but you could have other leaks. Best way to find out is do a thorough degreasing and wait to see if any more oil appears up on top.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
Similar Threads
Leak after leak, after leak Weatherlite 6.0L Power Stroke Technical Info 2 07-04-2016 02:15 AM
tuning issue or trans issue stroke of luck 6.0L Power Stroke Technical Info 11 01-07-2011 08:06 PM
Strange fueling issue or transmission issue????? NEVRNF Engine & Transmission Conversion 14 09-21-2009 07:05 PM
Tuning issue or Injector issue? PowerstrokeJunkie 7.3L Power Stroke - Aftermarket & Performance 12 11-01-2008 02:11 PM
CPS... The non issue issue... CSIPSD 7.3L Power Stroke Technical Info 61 08-27-2007 08:07 PM
