2005 6.0 No Hot Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 04-15-2019, 01:31 AM Thread Starter
CAT lover
Robertl211's Avatar
2005 6.0 dually no hot start
Did normal things, stand pipes and dummys, had it running good for a few weeks and then it died on the road and wouldn’t start again. Gave shot of ether and it fired up and we pulled into shop. ICP 300ish while cranking obviously HPO leak.
Pulling apart to do air test right now and new STC fitting. Truck has new injectors, oil cooler, correct oil filter and new standpipe/dummys.
Any advice? Truck has 105k miles and has ran well even with the HPO leak. How do I diagnose a bad HPOP? We are setting up to do air test now getting valve covers off and fitting installed etc.
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #2 of 27 (permalink) Old 04-15-2019, 01:32 AM Thread Starter
CAT lover
Robertl211's Avatar
Re: 2005 6.0 No Hot Start
When started with a shot of ether it runs mint. As soon as we shut it off it will not start again.
post #3 of 27 (permalink) Old 04-15-2019, 01:56 AM Thread Starter
CAT lover
Robertl211's Avatar
Plugged in shop air to ICP fitting, have air coming out both pass and drivers valve covers at oil fill and CCV ports. That is with IPR disconnected (so that means IPR open?). This doesn’t make sense to me.
post #4 of 27 (permalink) Old 04-15-2019, 02:27 AM Thread Starter
CAT lover
Robertl211's Avatar
On another positive note, we found some small (<1mm) chunks of aluminum in the oil filter....
post #5 of 27 (permalink) Old 04-15-2019, 07:35 AM
"resident smarty pants"
The IPR actuator defaults to being open with no power applied. A spring will hold it closed, but it won't be air tight. You have to command the IPR valve to the closed position to do an air test.
IMO the best way to do an air test is to buy and install the test fitting that goes into the IPT valve opening (must remove the IPR).
Mark
bismic1 is online now
post #6 of 27 (permalink) Old 04-15-2019, 12:40 PM Thread Starter
CAT lover
Robertl211's Avatar
Yeah getting a pigtail today to close the IPR and run another air test
What do you guys think about the aluminum? LPOP front cover? HPOP going? Could the no hot start and aluminum in the filter show a bad HPOP?
post #7 of 27 (permalink) Old 04-15-2019, 12:45 PM
matthewd11's Avatar
Aluminum could be from be the front cover or a piston. There would have to be something wrong with the LPOP or it sucked up something and damaged it for it to be from the front cover. There are no other wearable items that are aluminum in that engine other than those 2 things.
matthewd11 is offline
post #8 of 27 (permalink) Old 04-15-2019, 01:07 PM
Might be worth pulling the LPOP regulator and seeing if there are any particles there.
Mark
post #9 of 27 (permalink) Old 04-15-2019, 01:11 PM
matthewd11's Avatar
Agreed
post #10 of 27 (permalink) Old 04-15-2019, 06:01 PM Thread Starter
CAT lover
Robertl211's Avatar
Front cover is junk. Found a small chunk of ferrous metal on the oil drain. Going to replace front cover, oil pump, etc. and reassemble. Hope this solves the issues.
Similar Threads
No Start When Hot, Stalls Shifting Into Gears When Hot, Stalls When Turning Sharp zacksharpe5445 6.0L Power Stroke Technical Info 2 12-03-2017 11:45 AM
2005 ford 6.0L no start when hot and random stalls Motox26 6.0L Power Stroke Technical Info 1 03-29-2016 10:18 PM
2005 6.0 sometimes no hot start Bryan-R 6.0L Power Stroke Technical Info 8 02-16-2015 05:18 PM
2005 6.0 NO START WHEN HOT Farm5876 6.0L Power Stroke Technical Info 10 11-22-2012 02:00 PM
Cabin HOT HOT HOT while Towing. Why? JamesE 7.3L Power Stroke Technical Info 10 04-10-2011 04:50 PM
