ICP Issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-13-2019, 06:10 PM Thread Starter
ICP Issue
2004 F350 6.0; I had a bad #1 fuel injector so I tore it down and replaced it. With the ICP plugged in the engine turns over hard making the starter skip. With the ICP unplugged it starts fine....
I change the ICP and pigtail and have the same issue.
Scratching my head, please help.
Brian
Brianfordproblems is offline
post #2 of 3 (permalink) Old 04-13-2019, 06:38 PM Thread Starter
Re: ICP Issue
Also to be noted when it is running and I plug in the ICP it dies immediately.
post #3 of 3 (permalink) Old 04-16-2019, 12:24 PM
Weatherlite's Avatar
Garage
Re: ICP Issue
Is this problem with the ICP new since you changed the #1 injector, or did it exist before? If it's only since you did the replacement, I would re-trace your steps and see if you may have left off a connector, scraped off some wire insulation, angered a truck god....something. If it was there before, then I would still be looking at the wiring, only I wouldn't have a starting off point, so I'd probably begin with the ICP harness. Finding an intermittent short/open can be a real pain, but that's what I'm thinking. Never heard of these exact symptoms before. Maybe someone else will have a good suggestion. Good luck to ya!
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
Similar Threads
icp volts vs icp pressure 99strok3 7.3L Power Stroke Technical Info 3 11-20-2015 05:26 PM
30 psi ICP while cranking..no oil out of ICP hole. a5t1 7.3L Power Stroke - Aftermarket & Performance 20 04-04-2014 11:36 AM
New guy needs help ICP Problems with code P1212 ICP voltage not at expected level Moss 7.3L Power Stroke Technical Info 4 09-23-2013 03:00 AM
99 7.3 ICP Problems now have code P1212 ICP voltage not at expected level Need help!! Moss 1994-1997 Power Stroke Technical Info 0 09-22-2013 03:12 AM
Low ICP press. and ICP Code sg465 1994-1997 Power Stroke Technical Info 8 02-23-2010 11:21 AM
