Base oil pressure issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-08-2019, 09:31 PM Thread Starter
I have a 2004 6.0 that I had a long block built for and I cant get base oil pressure. If you crank it without starting it it will build over 70psi of pressure if you start it it wont built any pressure at all. I am at a loss and everyone I have talked to is also any help would be appreciated!
1960Fc170 is offline
post #2 of 3 (permalink) Old 04-08-2019, 10:39 PM
matthewd11's Avatar
That doesn’t make sense. The truck won’t run without base oil pressure. So how is it running with no base pressure? How long are you cranking it to achieve 70 psi of pressure?
matthewd11 is offline
post #3 of 3 (permalink) Old 04-09-2019, 12:08 AM Thread Starter
It is possible to run and not have base pressure when I first put the it in I had this problem and it ended up being a oil galley plug the builder left out. It takes probably 4 or 5 seconds to build 70 psi.
Similar Threads
06 quit while driving won't restart no base oil pressure charcoal07 6.0L Power Stroke Technical Info 7 06-16-2015 12:00 PM
7.3 Oil Pressure Issues (No pressure at idle) tractor_andy 7.3L Power Stroke Technical Info 8 09-24-2013 11:46 AM
filter base F-350 7.3L Power Stroke - Aftermarket & Performance 4 12-20-2008 04:46 PM
I have nothing to add to the tech base here... Billysgoat New To The Nation 22 11-01-2007 06:04 AM
