03 6.0 Battery light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-07-2019, 05:40 PM Thread Starter
fullmetaljacket90's Avatar
Not too long ago my battery light came on while the truck was running, then shut off, came back on again. I put the multi meter on the batteries and they are reading about 11.3 while the truck is off. Its not a daily driven truck so I parked it till I could figure out the issue. Started it up today, ran it for about 15 mins and went up and down the road. Battery light started coming on and off again, it shifted rough a few times, and after I parked it and shut it off it will not start back up. The gauges all jump back and forth as I try to crank it, it clicks, but does nothing else. I left the key in the ON position to try and get a read with the multi meter and there was a buzzing type sound coming from the passenger side battery area. Before I shell out the money for an alternator and new batteries I just wanted to know if there is anything else I should check first. Is this a potential FICM problem? Could it just be the batteries are bad and not the alternator? Also how big of an alternator is recommended? Not sure which one it has in there now, but I dont have any accessories on it, no extra lights or anything, and all it tows is my jon boat. Would really appreciate the help.
fullmetaljacket90 is offline
post #2 of 2 (permalink) Old 04-07-2019, 06:04 PM
"resident smarty pants"
Re: 03 6.0 Battery light
Most likely the alternator is bad when you get the battery light. IMO 190 amps is the right size.
A bad battery can ruin an alternator and vice versa. Charge the batteries and then load test them individually (not just a static voltage test).
Mark
bismic1 is offline
Similar Threads
Battery question what happens when your battery goes low? Bignbadbelair 6.4L Power Stroke - Technical Info 9 12-09-2013 01:10 AM
Where can I get small battery tray to replace my battery box? F250 Fever 7.3L Power Stroke Technical Info 11 02-18-2011 04:14 AM
battery charger for break away battery PSDnate Towing and Hauling - The Work Horse Forum 2 10-18-2010 12:46 PM
Changed Battery Cable and now Battery Light ON. Help... 99STROKINSMOKIN 7.3L Power Stroke Technical Info 18 09-19-2010 09:10 PM
Please help with heavy tractor battery- can add acid? Never seen a battery like this clydesdale General Questions & Discussion 5 05-17-2010 10:36 PM
