Need help with towing wiring - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-07-2019, 01:03 AM Thread Starter
techguy7.3's Avatar
Garage
I’ll try to be brief. 2003 F-350. Owned it for a few months now. Just realize it is not equipped with a trailer wiring connection at the bumper. Must never have been used to tow. I need help identifying what I need to purchase. I tried searching but there are many different harnesses and options that come up. Some look correct but they say only for 1999-2001. All I see under the bumper is a harness connector that has nothing plugged into it and I assume it is where I would plug something new into. It has 2 rows of four holes in the middle and then four pins I think, one on each corner. Also, will the brakes on my camper work if I don’t have a brake controller? If I need one how hard is that to install? Thanks for any guidance you can offer.
techguy7.3 is offline
post #2 of 5 (permalink) Old 04-07-2019, 09:10 AM
CAT lover
Robertl211's Avatar
Re: Need help with towing wiring
Brake controllers are plug and play to the harness under your dash above the transmission tunnel. You will need either the specific ford harness (your ford dealer can give you the right part number then buy online) or get a generic harness and splice it in. There are 7 wires to control your trailer. Red+black 12v hot and ground (power for your trailer brakes if they're not surge) green, brown, white and yellow. Those are brake lights, running lights, left and right blinkers. NOT IN THAT ORDER. A simple google search will give you which color is which circuit. Wire those 7 into a 7 way plug and your good. simple stuff just take your time.
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #3 of 5 (permalink) Old 04-07-2019, 12:45 PM
"resident smarty pants"
Don't forget the seventh wire - blue
Mark
bismic1 is offline
post #4 of 5 (permalink) Old 04-08-2019, 01:48 AM Thread Starter
techguy7.3's Avatar
Garage
Thank you for your replies. Would someone be willing to share a link that would show a 7 pin recepticle with a harness that would fit my 03? I see some that look like they would work but they say only for earlier models. They include 2 rests and two fuses. Is this not necessary for mine. The end I see yo under bumper has 8 holes in middle (2 rows of 4) and one pin in each of the four corners. Just hoping to find something I can plug in and not have to splice wires if I don’t have to.
post #5 of 5 (permalink) Old 04-10-2019, 12:37 AM Thread Starter
techguy7.3's Avatar
Garage
I’m wondering if it would be as simple as splicing a 7 pin connector onto this harness? It only comes with a 4 flat but looks like it has the extra 3 wires folded up as an option. Can anyone verify this idea would work? The gray harness connector is really what I’m after. This would plug into the available harness connector that’s up under bumper behind spare tire. I can’t find a 7 pin socket to mount to bumper that has that end as part of the kit. They all either come with a round connector or a t - connection. Seems like all I need is the single gray connector
File Type: jpg FFB83397-E3E5-4C0F-BA6A-3AED4217B554_1554856624905.jpg (10.0 KB, 10 views)
Similar Threads
Need wiring information for towing jst3751 1999-2010 Super Duty General Aftermarket 1 12-31-2016 07:29 PM
Pre-trip recommendations for towing with a 2000 7.3 liter used for towing 10 K equislover 7.3L Power Stroke - Aftermarket & Performance 9 03-29-2015 10:16 PM
Towing temps and issue with over 10k towing tlb017 6.4L Power Stroke - Technical Info 9 04-13-2012 04:51 AM
Need Help/Advise about towing dmoore 1994-1997 Power Stroke Technical Info 13 08-09-2011 05:05 PM
