Rotella T6 vs. Delo 400 XSP for my 6.0 ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-01-2019, 01:00 PM Thread Starter
IQRaceworks's Avatar
Question Rotella T6 vs. Delo 400 XSP for my 6.0 ?
Iíve had pretty good luck with running the Rotella T6 5w-40 in my 6.0. Iíve found a local shop that carries the Delo 400 XSP full synthetic oil for a good priceÖ.so Iím thinking about trying it out when I do my next oil change here pretty soon.
I did a little research, and it looks like the T6 is JC-4 rated, but the XSP from Delo is CK-4 rated? Something about using less phosphorus for lubricate because of emissions?
Should I stay away from the Delo 400 XSP 5w-40 in my 6.0? Or is it ok to run?
Thanks
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
IQRaceworks is offline
post #2 of 3 (permalink) Old 04-01-2019, 02:48 PM
Re: Rotella T6 vs. Delo 400 XSP for my 6.0 ?
I've been looking at that too. Costco sells that oil for a good price.
I'm using T6 now too. However, Wal-Mart recently increased their price so I am open to switching if others think it's good oil.
Sent from my Pixel 3 XL using Tapatalk
007matman is offline
post #3 of 3 (permalink) Old 04-03-2019, 12:35 PM
Weatherlite's Avatar
Garage
In a nutshell, Ford recommends only using oils which meet their OEM spec WSS-M2C171-F1, or any CJ-4 oil which only says CJ-4 in the little donut, not CJ-4/CK-4. So, if you see a straight CJ-4 oil, or a CK-4 oil which also says meets Ford spec WSS-M2C171-F1, it's safe to use according to Ford. HERE is their position statement.
Having said that, Ford is constantly in the process of testing oils to see if they meet their requirements, and you can go HERE to find that list of approved oils. For the record, Delo 400 XSP does not meet the Ford spec at this time. It may be just fine, but it hasn't passed the test yet. Based on this list, I would imagine you could find plenty of reasonably priced alternatives to Rotella.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
Similar Threads
Oil/Filter: Amsoil vs Delo vs T6 Bdsankey 1994-1997 Power Stroke Technical Info 9 07-08-2015 01:20 AM
Changing from Rotella T to Rotella T6 procedure. Goneracin 7.3L Power Stroke Technical Info 25 01-29-2014 11:06 PM
Delo Dino vs Delo Syn theoldgirl1990 1994-1997 Power Stroke Technical Info 0 10-17-2012 08:45 PM
Delo vs. Rotella Oil Temp matthewd11 Fluids Discussion 3 05-13-2009 02:12 PM
Delo 15-40 VS Rotella 15-40 BACDRAFT Fluids Discussion 17 03-16-2009 09:46 PM
