6.4 trans pan upgrade question - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 (permalink) Old 03-21-2019, 06:40 AM Thread Starter
I'm looking to do the 6.4 trans pan and filter upgrade on my 2006 F350 but I'm a little confused with the actual pan I need
I'm looking online and every 2008-10 pan I'm seeing looks exactly the same as my 06 pan. Externally at least. And every write up and youtube video I've watched, their pans look the same as mine.
Are the 08-10 pans the same externally but different internally?
I'm looking at getting this cheap pan which says it's for a 6.4 powerstroke
https://www.ebay.com/itm/New-Transmi...gAAOSwuUlb~gz4
and this filter
https://www.ebay.com/itm/Auto-Trans-...AAAOSwwZJcf~lp
Can anyone confirm that's what I need for the job?
koukimonster is offline
post #2 of 11 (permalink) Old 03-21-2019, 11:48 AM
PSN Newb - Lurker
Re: 6.4 trans pan upgrade question
I just upgraded my pan less than a week ago. The filter is right. The pans will look different on the inside. The deepest part of the sump is wider on the 6.4L pan, allowing for the highly improved FT-180 filter. Let me snoop around real quick and find the part number.
Michael S King is offline
post #3 of 11 (permalink) Old 03-21-2019, 12:06 PM
PSN Newb - Lurker
I found the following info on the Dornan aftermarket pan. Expect to pay $40-60 for an aftermarket pan. It references the oe part #:
3C3Z-7A194-AA
Also, do your trannie a favor and replace the TP Roll bypass filter behind your front bumper (Motorcraft part #FT-145).
post #4 of 11 (permalink) Old 03-21-2019, 06:51 PM Thread Starter
Thanks, I picked up that filter, and now I'm looking for pans. It's kind of confusing since externally they look the same. So many sellers have extremely cheap pans that make me wonder if it's the right thing
https://www.ebay.com/itm/Transmissio...EAAOSwXitcPoyk
This listing has the correct OEM part number and the correct dorman 265-822 part number as well
https://www.summitracing.com/parts/r...RoCmUsQAvD_BwE
Here on summit they have an actual dorman pan with the correct dorman part number. I may just end up ordering from them.
post #5 of 11 (permalink) Old 03-21-2019, 07:06 PM Thread Starter
I actually think the correct part number is 8C3Z-7A194-B
https://www.riffraffdiesel.com/trans...pan-6-0l-6-4l/ shows that part number as the upgraded 6.4 pan
and here
This listing on amazon shows this pan being bought with the FT180 filter
post #6 of 11 (permalink) Old 03-21-2019, 09:34 PM
"resident smarty pants"
and here
Sorry! Something went wrong!
You are correct on that part number and the filter part number is 8C3Z-7A098-D (FT180 is correct also).
IMO Dorman quality is suspect. They may have gotten this one right, but for critical parts, I don't trust them.
Michael S King likes this.
Mark
bismic1 is offline
post #7 of 11 (permalink) Old 03-21-2019, 10:41 PM Thread Starter
Sounds good, I got that FT180 filter and bought an OEM ford pan off of amazon. Looks like I'm good to go!
post #8 of 11 (permalink) Old 03-21-2019, 10:46 PM
When I did mine, I bought:
Filter: FT-180
Pan: 8C3Z-7A194-B
I feel like the filter didnt sit as solid as the old one. I wondered if i doubled up the filter gaskets, one on top of the other, it might sit better.
Other than that it was an easy swap.
2003 Excursion EB 6.0 PSD: BPD Oil Cooler, Water Pump, 7.3 fan adapter: Adrenaline Stock HPOP: APR Head Studs (One at a time): KC Turbo Billet Compressor: EGR Delete: Sinister Coolant Filter & Regulated Fuel Return: '08+ Oil Pan/Filter: SCT LiveWire TS+
Tte531 is offline
post #9 of 11 (permalink) Old 03-21-2019, 10:56 PM
PSN Newb - Lurker
I ‘upgraded’ to a deep sump pan. After towing and running some highway miles, I have to say it’s probably not much better than a stock pan. Transmission temps are about 5 degrees cooler while towing and 10 degrees cooler on the highway. That doesn’t justify the price. I did get to buy 6 extra quarts of Mercon SP... The biggest reason to upgrade is having the FT-180 filter.
voodooridr likes this.
post #10 of 11 (permalink) Old 03-22-2019, 01:19 AM Thread Starter
Yeah, I'm not really doing it for cooler temps although that will be helpful even if it's just a few degrees. It's mostly for the better filtration and the fact that I'll be changing my fluid and filter anyways. So really I'm just paying 68 bucks extra for a pan.
Similar Threads
question on oil pan adapter and pan torque psu927 6.0L Power Stroke Technical Info 1 12-18-2015 10:35 PM
Ats trans pan question braaap12 6.4L Power Stroke - Aftermarket & Performance 2 03-11-2015 05:23 PM
Trans pan drop question lght1 7.3L Power Stroke Technical Info 2 12-10-2012 03:49 PM
hole between engine oil pan and tranny pan? theham1105 7.3L Power Stroke - Aftermarket & Performance 26 03-27-2010 04:38 PM
E40D pan upgrade tycham 1994-1997 Power Stroke Technical Info 6 05-18-2009 06:44 AM
